Page 4 of 4 1 2 3 4
Re: Won't start, I am throwing in the towel [Re: mopar97] #2775904
05/18/20 07:03 PM
05/18/20 07:03 PM
irvine, california
stephen Offline OP
stephen  Offline OP
irvine, california
hi guys,
Today I have something good to report. I was able to free the jammed choke plate. HOORAY!!!!
Then I tried to start.... it was sooooo.... close, it wants to start, sooooo close.
I think we are onto something here.
Re: Won't start, I am throwing in the towel [Re: stephen] #2775936
05/18/20 08:37 PM
05/18/20 08:37 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If the choke was jammed shut the whole time, the gas is now in the oil and plenty of it. A stuck open choke is less headaches than stuck shut, big time.
Re: Won't start, I am throwing in the towel [Re: buildanother] #2775946
05/18/20 08:51 PM
05/18/20 08:51 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I can't imagine a stuck choke on an otherwise properly working carb causing THAT much fuel to get into the engine that it was squirting out the plug hole. It would be going out the exhaust as the engine turned over.
Re: Won't start, I am throwing in the towel [Re: CMcAllister] #2775957
05/18/20 09:11 PM
05/18/20 09:11 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
Are you running either a high performance fuel pump or an electric one? If so maybe you have too much pressure and you are flooding the cylinders.
Re: Won't start, I am throwing in the towel [Re: 57Fury440] #2776066
05/19/20 08:53 AM
05/19/20 08:53 AM
Central Mississippi
mopar97 Offline
mopar97  Offline
Central Mississippi
You may want to clean the spark plugs too. I am sure they are fuel fouled. Burn the tips with a lighter and clean them with brake clean. That may get it to fire up....
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: Won't start, I am throwing in the towel [Re: mopar97] #2776096
05/19/20 11:08 AM
05/19/20 11:08 AM
irvine, california
stephen Offline OP
stephen  Offline OP
irvine, california
hi guys,
yesterday I pulled #1 and #3 plugs, they are bone dry. I didn't pull out others.
mechanical fuel pump, not electric.
I am charging the battery, will let it sit for a day or two, then try to start it again.
thanks,
Re: Won't start, I am throwing in the towel [Re: stephen] #2776567
05/20/20 07:14 PM
05/20/20 07:14 PM
Ohio
lockjaw-express Offline
Ohio
Well, You got me hooked!!!
Please let us know the outcome, as I am sure that others are waiting for the first fire-up!!!
Mark
Re: Won't start, I am throwing in the towel [Re: lockjaw-express] #2776687
05/21/20 10:16 AM
05/21/20 10:16 AM
Quote
Well, You got me hooked! Please let us know the outcome, as I am sure that others are waiting for the first fire-up! Mark
X2!
Re: Won't start, I am throwing in the towel [Re: RapidRobert] #2776698
05/21/20 10:58 AM
05/21/20 10:58 AM
moparx Offline
moparx  Offline
make that x3 !
beer
Re: Won't start, I am throwing in the towel [Re: lockjaw-express] #2776705
05/21/20 11:26 AM
05/21/20 11:26 AM
N
NITROUSN Offline
NITROUSN  Offline
N
The poster needs to hire a good mechanic for one hour and the car would be running.
Re: Won't start, I am throwing in the towel [Re: NITROUSN] #2776951
05/22/20 09:36 AM
05/22/20 09:36 AM
Iceland
BadMoonRacer Offline
Iceland
I disagree. This guy is in a steep learning curve and honest in his descriptions. When he has fixed the issue, he will be wiser and more talented, than if a mechanic fixes it and takes his money. Cudos to everybody who steps in to help him.
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials.
Icelandic Champion in MC 2007, 2008, 2009 and 2022.
Re: Won't start, I am throwing in the towel [Re: BadMoonRacer] #2777001
05/22/20 12:22 PM
05/22/20 12:22 PM
moparx Offline
moparx  Offline
the best lessons learned are the tough ones learned by yourself.
beer
Re: Won't start, I am throwing in the towel [Re: moparx] #2777876
05/24/20 11:23 PM
05/24/20 11:23 PM
GA
roadrunninMark Offline
GA
Anything yet?
Re: Won't start, I am throwing in the towel [Re: moparx] #2778190
05/25/20 09:44 PM
05/25/20 09:44 PM
The Garden State
LimelightCuda Offline
The Garden State
Originally Posted by moparx
make that x3 !
beer
Make that x4! I am looking forward to hearing you got it running! Keep us posted.
Phil
1970 Barracuda Gran Coupe
1970 A66 Challenger Convertible
Re: Won't start, I am throwing in the towel [Re: LimelightCuda] #2779152
05/28/20 04:42 PM
05/28/20 04:42 PM
57Fury440 Offline
57Fury440  Offline
What happened? Did you get it running?
Re: Won't start, I am throwing in the towel [Re: mopar97] #2785510
06/14/20 08:38 PM
06/14/20 08:38 PM
irvine, california
stephen Offline OP
stephen  Offline OP
irvine, california
hi guys,
finally got some time this weekend, worked on the car a little bit.
was able to pry open the plate, it works fine now.
interesting new discovery: when throttling, the gas is not spraying from the jet, instead it is flowing like a facet. way too much gas. it wanted to start, but then always have big loud backfire.
it is a eldelbrok 4 barrel, there are two screws in the front to adjust air mixer, no matter what I do with them, still too much gas.
please help.
Re: Won't start, I am throwing in the towel [Re: stephen] #2785514
06/14/20 08:47 PM
06/14/20 08:47 PM
Quote
bad needle/seat or float or float linkage & eddys dont like more than 5&1/2 lbs fuel psi & alot of OE pumps put out way more than that.
Page 4 of 4 1 2 3 4
