any dodge techs out there? 2007 dakota help #278520
04/05/09 07:58 PM
04/05/09 07:58 PM
auburn,N.Y.
71RR ED Offline OP
71RR ED  Offline OP
auburn,N.Y.
hey my dads 2007 quad cab 4x4 has a serious brake issue as in they go to the floor.no leaks visible,feels like a bad master cylinder,but am unsure if ABS system could cause same affect.the truck has just over 36,000 miles on it,had to have swaybar links and 1 tierod end replaced under warrentee not very happy with issues this early on.not built like 1st generation from what I can tell.any response would be great,thanks
Re: any dodge techs out there? 2007 dakota help [Re: 71RR ED] #278521
04/05/09 08:34 PM
04/05/09 08:34 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Sounds like a bad Master Cylinder, and dash lights on? Happen every time? Fluid look black? (I know its a 07)
Re: any dodge techs out there? 2007 dakota help [Re: SALEM1912] #278522
04/05/09 08:46 PM
04/05/09 08:46 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
my 05 quad cab 4x4 has had the following in 35,000 miles.
both front wheels bearings
both front sway bar ends
new rear brakes, drums turned.
front rotors and pads, only thing covered by warranty.
rear drums are warped again
Re: any dodge techs out there? 2007 dakota help [Re: SALEM1912] #278523
04/05/09 10:21 PM
04/05/09 10:21 PM
auburn,N.Y.
71RR ED Offline OP
71RR ED  Offline OP
auburn,N.Y.
no dash lights fluid is clean and clear
Re: any dodge techs out there? 2007 dakota help [Re: 71RR ED] #278524
04/06/09 07:18 AM
04/06/09 07:18 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
if the question is will ABS caues these symptons ? No
sounds like an internal master cylinder leak.
