Odd question regarding factory undercoating #278515
04/05/09 07:57 PM
04/05/09 07:57 PM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
How do you clean it? Huh? Yea, how can you clean undercoating, or can you?
The factory undercoating on my 68 Charger is 40 years old of course (actually it's 43 now) and obviously it's showing wear and it's dirty, as in road grime dirt. I've spent a few hours so far scraping off the loose coating but what I can't figure out how to deal with the dirt that's stuck to what remains. My plan is to recoat the areas where it was scraped with new but I don't want a bunch of new black patches next to the dirty brown spots. I tried a wire brush and that did next to nothing. Would a wet, stiff-bristled brush work you think? I wouldn't think spraying new coating on top of dirty old coating would be a good idea. Ideally pressure washing it might do the trick but that's just not practical in my situation.
Before you tell me to heat it up and scrape it all off just know that ain't going to happen. I like the stuff and I want it to stay.
1968 Charger 383/2bbl/4spd (1 of 74) 1994 Dakota Sport 3.9L/AT/2WD 2003 Durango SLT 4.7L/AT/4X4 Yes, all Dodges and nothing else
Re: Odd question regarding factory undercoating [Re: bull] #278516
04/05/09 08:00 PM
04/05/09 08:00 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Maybe try a spraying a little wax and grease remover on it? It shouldn't take it off like an aggressive solvent would.
Re: Odd question regarding factory undercoating [Re: Neil] #278517
04/05/09 08:04 PM
04/05/09 08:04 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I got a lot of dirt off of mine by using slow drying laquer thinner in a regular paint gun. I sprayed it on wet & the dirt "dripped" off with it.
Re: Odd question regarding factory undercoating [Re: bull] #278518
04/05/09 08:21 PM
04/05/09 08:21 PM
SE Pa.
LimeliteAero Offline
SE Pa.
power wash or I used a pressurized pump sprayer that you use to spray weed killer. fill with purple power or whatever and spray it down followed by a water rinse. if needed use a scrub brush.
of course after you apply your undercoat you go back and paint the existing undercoating and blend it to the new stuff.
Re: Odd question regarding factory undercoating [Re: LimeliteAero] #278519
04/05/09 08:42 PM
04/05/09 08:42 PM
Western Oregon
bull Offline OP
bull  Offline OP
Western Oregon
Here's one solution I found linked below. It's the only thing I've been able to find on the topic so far besides the advice here (for which I'm thankful).
http://www.ask.com/bar?q=how+to+clean+un...m%2Fpage141.htm
You know, after reading what all he went through it almost seems like it would take about as long to scrape it and start over.
