Steering Gear Pulls to the Left? #278507
04/05/09 07:46 PM
04/05/09 07:46 PM
Massachusetts
LYNCHROAD69.5 Offline OP
Massachusetts
I just started my car for the first time in 1.5 years and as part of the restoration I had my power seering box rebuilt by Steer & Gear....they put firm feel in the box and it looks great. Well, today I started the car and all was great except for the steering box....steering wheel spins all the way left (unassisted) and I have no assit turing right....thought it might be air but after turning the wheel back and forth 4 to 6 time same thing. My fear is something major and the box will need to come out (pain in the $#&*@) and go back. Anyone know what might be causing this and maybe some trouble shooting tips before I have to remove.
Re: Steering Gear Pulls to the Left? [Re: LYNCHROAD69.5] #278508
04/05/09 07:56 PM
04/05/09 07:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It is a minor fix, you just need to adjust it. Do you have the factory service manual?
Re: Steering Gear Pulls to the Left? [Re: LYNCHROAD69.5] #278509
04/05/09 07:56 PM
04/05/09 07:56 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
You just need to adjust/reposition the valve.
the valve is were the return hose is connected.2 7/16 bolts(if I remember right)loosen the 2 bolts slightly,then tap/move that valve alittle.will be trial and error,shouldn't take too long.easy,don't loosen too much,don't need to move it much,shouldn't have a problem with a leak either.
Re: Steering Gear Pulls to the Left? [Re: LYNCHROAD69.5] #278510
04/05/09 07:57 PM
04/05/09 07:57 PM
Delaware shore
68Barracuda Offline
68Barracuda  Offline
Delaware shore
Someone else will probably chim in with more info, but don't panic or pull it yet. If it's set up like a standard mopar box you adjust it by loosening the two bolts on top where the hose comes out and you shift it a bit one way or the other to fix the problem. There is an o-ring under there so be carefull. If you have a manual it will describe the procedure. Don't jump in on my advice as I have only done it once with the help of a mechanic friend, But it is fairly simple. Good luck with it.
Re: Steering Gear Pulls to the Left? [Re: LYNCHROAD69.5] #278511
04/05/09 07:57 PM
04/05/09 07:57 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Loosen the 2 bolts that the hose attaches to the box and then tap it alittle.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Steering Gear Pulls to the Left? [Re: moretoys] #278512
04/05/09 07:58 PM
04/05/09 07:58 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
it's the bolts right on the gearbox,facing down.
Re: Steering Gear Pulls to the Left? [Re: moretoys] #278513
04/05/09 08:00 PM
04/05/09 08:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Steering Gear Pulls to the Left? [Re: Alaskan_TA] #278514
04/05/09 08:28 PM
04/05/09 08:28 PM
Massachusetts
Massachusetts
I have factory service manual....thanks for all the quick responses
