RPM at 60mph?
#2784872
06/13/20 10:21 AM
06/13/20 10:21 AM
Posts: 670 Third rock from the sun.
busboy
70’ b-body, 440 with an 833 (1967), 3:55 and a 28” tall tire. The online calculators show I should be turning 2500-2600 rpm at 60mph, I’m turning 3000rpm. I’ve confirmed the cars speed with a gps so not sure what’s up with my combination. What rpm are you folks turning using a similar set up?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: RPM at 60mph?
[Re: 440_Offroader]
#2784930
06/13/20 12:14 PM
06/13/20 12:14 PM
Posts: 374 Alberta, Canada
300rag
Alberta, Canada
My Challenger with a 383/727/3.55 runs 3000rpm @ 60mph. I have 255/60/15 rear tires, not sure the diameter. I thought it kind of high myself. Not sure if the tach is not reading correctly, or torque converter slipping some? I verified my gears when I had the case out, thinking the gears may have been changed, but they were correct to the tag. 255/60 is a 27" diameter, giving 2660 RPM with no slip.
Peter
'65 300 'vert 413/4spd '18 Challenger R/T Shaker '19 Durango R/T
Re: RPM at 60mph?
[Re: busboy]
#2784933
06/13/20 12:21 PM
06/13/20 12:21 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
70’ b-body, 440 with an 833 (1967), 3:55 and a 28” tall tire. The online calculators show I should be turning 2500-2600 rpm at 60mph, I’m turning 3000rpm. I’ve confirmed the cars speed with a gps so not sure what’s up with my combination. What rpm are you folks turning using a similar set up? Verify the axle ratio if you didn't install them yourself. 275/60/15 tires? If the axle and tire diameter check out, it's time to check your tach calibration. Kevin
Re: RPM at 60mph?
[Re: 300rag]
#2785261
06/14/20 09:22 AM
06/14/20 09:22 AM
busboy
That’s sure what it sounds like 300rag! I assembled the 3:55 pig myself but the shop installed it, think I will jack it up and spin the wheel for a rough check. They could have put in the wrong one😳!
Re: RPM at 60mph?
[Re: Twostick]
#2785265
06/14/20 09:25 AM
06/14/20 09:25 AM
busboy
Correct Kevin, 275/60 15 tires. Tach calibration is a good call, freshly restored dash/gauges but it sure sounds like it’s buzzing high.
Re: RPM at 60mph?
[Re: busboy]
#2785334
06/14/20 11:38 AM
06/14/20 11:38 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I checked yesterday to make sure where it is with my combo.
'68 Barracuda convertible, 408 Magnum based EFI's motor ((382hp & 525 ft lbs of torque at the wheels)), Stage 2 Extreme Automatic's 2004R transmission with a 3800 rpm lock-up torque converter and 3.91's turning 28" tall 275/60-15 Nitto Drag Radials. It spins 1950 rpm at 60 mph and gets 17+ mpg with the top down.
The 2004R is the best transmission I've ever had the pleasure of owning. With the lower 1st gear ratio, it's the equivalent of having 4.30 gear ratio out of the hole. The car only spins for 10 feet and then dead hooks before it goes through the rest of the gears. It gets up to 60 mph pretty quick too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: RPM at 60mph?
[Re: jbc426]
#2785612
06/15/20 09:45 AM
06/15/20 09:45 AM
Posts: 16,148 Mesa, Arizona
dart4forte
Mesa, Arizona
The 2004R is the best transmission I've ever had the pleasure of owning. With the lower 1st gear ratio, it's the equivalent of having 4.30 gear ratio out of the hole. The car only spins for 10 feet and then dead hooks before it goes through the rest of the gears. It gets up to 60 mph pretty quick too. Man, I love that Cuda
Abe Lincoln
Re: RPM at 60mph?
[Re: busboy]
#2786171
06/16/20 10:49 PM
06/16/20 10:49 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
I was turning 3100 rpm at 60mph with 3.91's, 26's and A833, so, I think you are in the ballpark. Life is better these days with overdrive and 3.23's: 1700 rpm and + 4 mpg. No loss of acceleration either. Not sure why a 426 needs Slant Six gears to perform? .
Mo' Farts
Moderated by "tbagger".
Re: RPM at 60mph?
[Re: busboy]
#2786202
06/17/20 12:55 AM
06/17/20 12:55 AM
Posts: 31,042 Oregon
AndyF
70’ b-body, 440 with an 833 (1967), 3:55 and a 28” tall tire. The online calculators show I should be turning 2500-2600 rpm at 60mph, I’m turning 3000rpm. I’ve confirmed the cars speed with a gps so not sure what’s up with my combination. What rpm are you folks turning using a similar set up? 3000 RPM with 3.55 gears and a 28 inch rear tire is a little over 70 mph. So one of your numbers is wrong. Not sure which but something in your equation is wrong. You were in fourth gear correct? 3000 rpm at 60 mph with a 28 inch tire requires more than a 4.10 gear. I have 4.56 gears in my Duster and it turns 3000 RPM at 60 mph with a 31 inch rear tire.
Re: RPM at 60mph?
[Re: Sniper]
#2786734
06/18/20 10:28 AM
06/18/20 10:28 AM
Posts: 6,003 Salem
Grizzly
Salem
Not sure why a 426 needs Slant Six gears to perform? Because the most affordable way to put an OD manual trans behind a Hemi is the A833. All other options are multiples in additional cost. I was talking about the "need" to have 4.10's with a Hemi.
Mo' Farts
Re: RPM at 60mph?
[Re: AndyF]
#2792203
07/03/20 09:00 AM
07/03/20 09:00 AM
busboy
Thanks Andy, here’s the update. Haven’t been driving much lately but was finally able to get out in the car. Tried the gps again, turns out at 60mph gps shows 65mph so speedo is under reading by 5mph. When I slow to 55mph (60mph gps) my revs are at 2800rpm, seems a little better. I’m using the yellow 33 tooth speedo gear which I thought was correct for 3:55 gears, may have to change that. Next thing to check would be the accuracy of the tach, anyone have any idea how to I would go about that??
Re: RPM at 60mph?
[Re: busboy]
#2792215
07/03/20 09:19 AM
07/03/20 09:19 AM
Posts: 10,723 North Dakota
6PakBee
North Dakota
Next thing to check would be the accuracy of the tach, anyone have any idea how to I would go about that?? The best way would be to use a square wave generator. Sometimes technical colleges have them for electrical classes. If you are handy electrically, there are gobs of articles on the web how to build one using an op-amp but I'd see if I could borrow or use one before I resorted to that.
