Re: 828-16 comp lifters
[Re: 6d7hemi]
#2784323
06/11/20 09:45 PM
06/11/20 09:45 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Anybody know what the roller wheel diameter is for comp 828-16 small block roller lifter? Thanks If no one responds I can tell you tomorrow. Really disappointed in my last set after the tie bar broke in my sons 10.20-10.30 360 and destroyed the cam and engine. 60 runs on them.
[Re: pittsburghracer]
#2784371
06/11/20 11:19 PM
06/11/20 11:19 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Anybody know what the roller wheel diameter is for comp 828-16 small block roller lifter? Thanks If no one responds I can tell you tomorrow. Really disappointed in my last set after the tie bar broke in my sons 10.20-10.30 360 and destroyed the cam and engine. 60 runs on them. Was that a non-removable link bar with a full rivit, or the removable type that you rotate verical to remove? Just curious as to which and if it was the removeable type, if that could have had anything to do with the breakage. Not that it should.
[Re: Chargerfan68]
#2784677
06/12/20 04:24 PM
06/12/20 04:24 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Anybody know what the roller wheel diameter is for comp 828-16 small block roller lifter? Thanks If no one responds I can tell you tomorrow. Really disappointed in my last set after the tie bar broke in my sons 10.20-10.30 360 and destroyed the cam and engine. 60 runs on them. Was that a non-removable link bar with a full rivit, or the removable type that you rotate verical to remove? Just curious as to which and if it was the removeable type, if that could have had anything to do with the breakage. Not that it should. Sorry busy day today. It’s a non removable bar and with my cheap digital caliber measures .799-.800 wheel.
