Carburetor & Intake Compatibility Question
#2784076
06/11/20 12:07 PM
06/11/20 12:07 PM
Posts: 3,457 Newburgh, NY
Old_Moparz
Newburgh, NY
I'm sure someone on here can help me with a question I have before I make another purchase of a wrong part. I have a stock 318-2V in my 1969 Satellite that I am going to swap out for a 4V set up. The existing 2V carb is shot, but instead of spending time & money on the 2V for a motor that I had planned to have rebuilt next year, I figured I would put the new 4V on now to drive the car this summer. I've gathered the parts I needed, or so I thought, but when I finally went to dig into the project I discovered that the carb I bought a couple of years ago doesn't fit the intake I bought. The carb is a brand new, 500 cfm, Carter AFB 9511 that was still in the plastic wrap inside the box & the intake manifold is a stock, Chrysler cast iron piece for a 340, from 1972-73 I believe. I don't have the casting number handy but the intake manifold has the wider gap between the two front primaries for a Theromquad carb. The Carter AFB I have is much smaller & the throttle plates are closer together so they hit the intake manifold. I see that the older 340 intakes have the front openings closer together. Will the Carter AFB 9511 I have fit this intake? (see photo) Would it be better to hunt for & use an intake for a 1966-67 273-4V? I really don't want to drop $350 or more on a new carb that will fit the 340 intake I have. It seems that replacing the intake is a much cheaper alternative. I'd consider a spacer/adapter, but then I get into height issues & don't want to have to rig linkages or end up with hood clearance problems. Thanks.
Re: Carburetor & Intake Compatibility Question
[Re: Cab_Burge]
#2784163
06/11/20 03:01 PM
06/11/20 03:01 PM
Posts: 6,279 nowhere
Sniper
nowhere
The 340 and 360 intake ports on the heads and intake manifold are larger than the 318 heads and intake ports which will cause reversion That is really a non-issue except in a max effort engine build and you wouldn't being doing that to a 318 anyway. I don't know why people keep bringing that old chestnut up, got any dyno pulls to prove it is an issue? All that said, I ran the factory spreadbore intake on my otherwise stock 87 2bbl 318, yes the small port heads with zero reversion issues. Ran an Edelbrock 1406 carb on it without an adapter. What I did was run a thick (~3/8") carb base gasket. Don't have a PN though, I just picked it off the shelf back when there were speed shops and carb mounting gaskets to look at. Might look at Edelbrock Carburetor Adapters 2732, it's about as thin an adapter as you will see, probably thinner than my thick gasket trick. You will also need the kickdown linkage addressed as the 2bbl stuff doesn't play so well with a 4bbl, did you get the adapter for the throttle and kickdown linkage as well?
[Re: Sniper]
#2784168
06/11/20 03:20 PM
06/11/20 03:20 PM
RapidRobert
Just thinking out loud. what about building a 360 (or even a stroked 360) on the side. It'd minimize your down time when it came time to swap & there'd be a significant gain in torque which you could definitely use.
[Re: Sniper]
#2784176
06/11/20 03:36 PM
06/11/20 03:36 PM
Old_Moparz
Newburgh, NY
You will need an adapter to go from the spread bore manifold to the square bore carburetor or find an early 340 intake. The intake you have has larger ports than your 318 heads. It will work, but won't be ideal. If you are going to stick with the 318, at the very least you should add 360 heads when you rebuild it to match the ports. I do have a '69 340 intake that I am selling, but shipping from California would be about the same as what I want for the manifold... The Carter AFB 9511 that I have may be a square bore, but the front primaries are smaller & not as far apart as the openings on the 340 manifold. The ideal adapter would be a wide to narrow spread bore if such a thing exists. The fear with adding an adapter is linkage issues & hood clearance because the 340 manifold is already substantially taller than the 318-2V manifold on there now. I did see your ad & agree that the shipping would be crazy. I was hoping to score something local or even meet someone at Carlisle to pick it up. The 340 and 360 intake ports on the heads and intake manifold are larger than the 318 heads and intake ports which will cause reversion Sell the Thermoquad intake and buy a AFB style 318 intake so the motor will like your changes Been looking for a different intake that's reasonable but no luck yet. The 340 and 360 intake ports on the heads and intake manifold are larger than the 318 heads and intake ports which will cause reversion That is really a non-issue except in a max effort engine build and you wouldn't being doing that to a 318 anyway. I don't know why people keep bringing that old chestnut up, got any dyno pulls to prove it is an issue? All that said, I ran the factory spreadbore intake on my otherwise stock 87 2bbl 318, yes the small port heads with zero reversion issues. Ran an Edelbrock 1406 carb on it without an adapter. What I did was run a thick (~3/8") carb base gasket. Don't have a PN though, I just picked it off the shelf back when there were speed shops and carb mounting gaskets to look at. Might look at Edelbrock Carburetor Adapters 2732, it's about as thin an adapter as you will see, probably thinner than my thick gasket trick. You will also need the kickdown linkage addressed as the 2bbl stuff doesn't play so well with a 4bbl, did you get the adapter for the throttle and kickdown linkage as well? Years ago I did the same swap on my 318 Scamp for almost the exact same reason, to not spend money on a beat 2V knowing I was going to switch to a 4V anyway. It ran fine with the stock 318 with an Edelbrock Performer & a Holley 600. When I had the motor rebuilt a year later with a bigger cam & some other mods I reused the same intake & carb & it ran a 15 second quarter with the 7-1/4" rear & 2.76 gears. I do have that same 2732 adapter but it's not going to fix my issue. I need more even height to clear the cast iron between the two openings. That's why I was mainly asking if anyone knows whether the carb will fit on an older 340 manifold. Of all the things I've been reading the carb I have is for the 273 Commando. I am aware of the linkage differences & had found what I needed in a junkyard back then. This time the parts were available new & I bought them from Mancini. Thanks guys.
[Re: RapidRobert]
#2784185
06/11/20 04:01 PM
06/11/20 04:01 PM
Old_Moparz
Newburgh, NY
Just thinking out loud. what about building a 360 (or even a stroked 360) on the side. It'd minimize your down time when it came time to swap & there'd be a significant gain in torque which you could definitely use. I'm always looking at local ads for some kind of small block in running condition but I'd like to avoid the additional expense & save it for other improvements later. When I bought a package deal of parts a couple of years ago for things needed on my son's Coronet & my Scamp, it also included the 340 intake. I later got the new carb, brackets, linkages, gaskets, filter, etc., but wrongly assumed the carb would fit.
[Re: Mr.Yuck]
#2784515
06/12/20 09:51 AM
06/12/20 09:51 AM
Old_Moparz
Newburgh, NY
I'm running a Thermoquad intake with a square based Holley. I am using a square bore spacer about 1/2 inch thick and it works perfect. I also have a small block Thermoquad intake with the small intake runners. They were used on 318 and 360 engines around 80-83 and possibly later. I am planning on using it for a 318 in a Dart. Good to know, thanks. Any reason you cant just take a die grinder to the offending metal? I'm afraid of sparks. Seriously, that's not a bad idea & I will take a look at the intake this weekend. Just buy the adapter and be done if you want to go 4bbl route. You know I had 3 or 4 of these adapters in a box years ago that came wirh a variety of cars & parts over the years. I put them out at a swap meet & gave one to a friend & wish I had kept one to try out to make sure clearance would be okay.
[Re: Sniper]
#2787629
06/21/20 02:12 AM
06/21/20 02:12 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
The 340 and 360 intake ports on the heads and intake manifold are larger than the 318 heads and intake ports which will cause reversion That is really a non-issue except in a max effort engine build and you wouldn't being doing that to a 318 anyway. I don't know why people keep bringing that old chestnut up, got any dyno pulls to prove it is an issue? Dude, do you know what your talking about? The early 273/318 heads had a lot smaller intake port than the 1968 to 1974 340 and 360 heads had, a lot smaller I'm not sure what year Mopar started offering the 318 motors with the smaller 318 heads and then the larger 360 smog heads with cast iron intakes made for those specific heads with a Thermoquad carb., maybe 1976 or 1978 era I have made the mistake of putting a stock cast iron 1968 340 AVS intake on a near stock 318 motor with a bigger cam and stock heads, talk about reversion and harm to the throttle response, that motor had it As far as how many dyno pulls and test sessions I've have been involved with on legal SB Mopar V8 NHRA stocker motors it is over hundred so far, how about you?
[Re: Cab_Burge]
#2787641
06/21/20 06:25 AM
06/21/20 06:25 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I agree w Cab, for a few years Edelbrock made a 4 bbl 318 manifold w 318 sized ports....I have one of these on an otherwise stock engine w headers and it runs better, has throttle response like no other 318 I've ever had. It will effortlessly spin a rear tire on my Challenger vert. Keeping the velocity in the intake ports up is very important for good torque and cylinder filling.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: Cab_Burge]
#2787692
06/21/20 10:44 AM
06/21/20 10:44 AM
Sniper
nowhere
Same number as you've done with the big port intake on the small port heads, which was the question asked. This isn't the race forum where you turd polish an engine to rules complying perfection and if you had issues with the big port intake on the small port heads my experiences running them ON THE STREET doesn't match yours. It has always been an improvement over the 2bbl setup. Which is exactly what the OP is asking about. As an aside, Edelbrock still makes a 4bbl intake with small ports, it's called the Performer and running one of those on my 318 is exactly the same as running a stock 4bbl intake on small port 318. BTDT.
[Re: Sniper]
#2787897
06/21/20 08:47 PM
06/21/20 08:47 PM
Cab_Burge
As an aside, Edelbrock still makes a 4bbl intake with small ports, it's called the Performer and running one of those on my 318 is exactly the same as running a stock 4bbl intake on small port 318. BTDT. Your wrong on this, don't mislead the masses that don't know any better The early DP4B ( I think that is the correct model number, I only had one of those )dual plane 4 barrel intake is probably the predecessor to the current 318 performer. All of you that don't know the differences in the port size take a hard look at the intake gaskets for the 273/318 and the 340//360 heads and make up your own minds I put a 1968 stock Mopar 340 cast iron intake on my Sons 1967 Baracuda fast back along with a Carter 500 CFM 4 barrel, it drove horrible. I swap the heads for a set of 1972 small valve 340 heads and had them cut to the correct CC for the 318 heads on his motor, that corrected the reversion problems and help it drive a lot better
[Re: Cab_Burge]
#2787910
06/21/20 09:21 PM
06/21/20 09:21 PM
HemiRick
Memphis
I'm 56 yrs old and my 1st engine was a 318 I modified that engine with 340/360 intake carb and headers and it was a dog compared to the 318 small port intake on the current 318 in the Chally vert., I've owned many 318's in my 30 yrs of driving mopars and a big port intake on a 318 sucks. I know from experience.
