rb roller cam #278353
04/05/09 04:48 PM
04/05/09 04:48 PM
wisconsin
jp66charger Offline OP
wisconsin
I've got a 493 with Scott Brown flat tappet mechanical cam, eddy performer heads, and crane 1.5 roller rockers. Any one tell me what what it would cost to go roller cam in this setup? Thanks, JP
Re: rb roller cam [Re: jp66charger] #278354
04/05/09 04:55 PM
04/05/09 04:55 PM
Chicago land, IL
dafixr Offline
dafixr  Offline
Chicago land, IL
Our cam was about 320.00,lifters and push rods was around 350.00. Plus you may need springs to match cam and a new timing chain also.
Good Luck
Re: rb roller cam [Re: dafixr] #278355
04/05/09 05:02 PM
04/05/09 05:02 PM
wisconsin
wisconsin
Thanks, hadn't thought about timing chain, I figured cam, lifters, push rods, springs. Then a friend of mine said locks and retainers as well as maybe some machine work on the heads for a taller spring. Starting to add up fast, but wasn't sure what actual cost is to do swap. JP
Re: rb roller cam [Re: jp66charger] #278356
04/05/09 05:38 PM
04/05/09 05:38 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
You will need a bronze dist. gear and a thrust button also. It usualy cost about $1,000.00 to $ 1,500.00 to convert over.
Re: rb roller cam [Re: drag440] #278357
04/05/09 05:53 PM
04/05/09 05:53 PM
quote]You will need a bronze dist. gear and a thrust button also. It usualy cost about $1,000.00 to $ 1,500.00 to convert over.
I figure right at $1000.00 for using a solid roller race cam in a new motor versus a flat tappet or hydraulic cam in the same motor the cost depends on the parts used, the lifters can be a big difference in price. Buy the good ones now
Re: rb roller cam [Re: jp66charger] #278358
04/05/09 06:02 PM
04/05/09 06:02 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Don't forget the springs and retainers.Also do you have enough notch in the piston is a factor too
Gus
64 Plymouth Savoy
Dana 60
Re: rb roller cam [Re: fourgearsavoy] #278359
04/05/09 06:55 PM
04/05/09 06:55 PM
wisconsin
wisconsin
Don't know about the piston yet, that is a variable tbd when heads come off this week. I really appreciate all the good info. Thanks again.
