Re: FRONT MOTOR PLATE
[Re: A/MP]
#2783289
06/09/20 03:42 PM
06/09/20 03:42 PM
Posts: 31,061 Oregon
AndyF
Use the transmission mount as the locating feature and work from there. Slide a long tube thru the mains and the transmission case. Line it up so tube points to the pinion then you lock it down.
[Re: A/MP]
#2783437
06/09/20 10:12 PM
06/09/20 10:12 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
That's some good info. There's no rear in it. Usually I use the motor and trans to locate the rear. So, do I use the motor/trans pipe system and locate the rear after I've bolted the motor and trans in first? I wouldn't do that Use the trans tunnel center for alignment on the trans and make sure and do as Andy suggested, use the headers to locate the engine in the engine bay
[Re: A/MP]
#2783489
06/10/20 01:03 AM
06/10/20 01:03 AM
AndyF
That's some good info. There's no rear in it. Usually I use the motor and trans to locate the rear. So, do I use the motor/trans pipe system and locate the rear after I've bolted the motor and trans in first? Well you can but locating the rear is more complicated than that. Typically you need the rear end to be centered within the frame and the body so you have proper tire clearance on both sides of the car. If I'm building a car I'd worry about that more than perfect alignment with the engine and trans since you have u-joints in the driveshaft to pick up the play. Of course, all this depends on the car. A tube chassis car is a little easier to build than a car with a stock floor. On a 50 year old car with a stock floor you often have no idea where to find a datum. Nothing is straight on those cars after 50 years of abuse so it gets harder to figure out what exactly you are squaring things up to.
[Re: A/MP]
#2783968
06/11/20 06:36 AM
06/11/20 06:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Find the center line of the car first thing.. the engine and trans is normally about 1" to he pass side of the car for driver clearance.. if you use the center line method it will help in building the whole car.. everything on a car is based on the center line
