Re: trans fluid bleed back
[Re: stumpy]
#2783219
06/09/20 01:23 PM
06/09/20 01:23 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
transgo sells what they call a no yoyo kit to stop bleed down. It doesn't prevent drain back but it does allow the converter to refill in Park.
[Re: lewtot184]
#2783435
06/09/20 10:06 PM
06/09/20 10:06 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
the simple solution is start the car in neutral. the trans pump doesn't work in park. starting in neutral lets the trans pump fluid immediately. I disagree on that statement on the pump The front trans pump works any time the motor is running The stock valve bodies don't circulate the tranny fluid in park., but that can be fix as already pointed out The anti drain back valve on top of the valve body is usually the reason for the converter to allow the fluid in it to drain back into the tranny, which can result in slow fluid filling and making the tranny not work as soon as you start to use it
[Re: dynamite]
#2783904
06/10/20 09:44 PM
06/10/20 09:44 PM
Posts: 18,418 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
My trans bleeds fluid back and takes several seconds before car can move... runs well once it's going.. but if it sits for only an hour or so it does the same thing..I know there is a bleed back kit or something but don't know where to get it .. Where can I but this ? 727 BB If it drains back that quick you have something wrong. I suspect something wrong or missing in the valve body.
[Re: NITROUSN]
#2784066
06/11/20 11:51 AM
06/11/20 11:51 AM
John_Kunkel
Rio Linda, CA
A really worn front pump bushing will allow more rapid drain back. There is a drain cavity in front of the bushing that leads directly to the sump.
