Page 1 of 3 1 2 3
543 440 Combo's #2781415
06/04/20 03:26 PM
06/04/20 03:26 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
What do you guys think of this combo in a stock block with a girdle?
Re: 543 440 Combo's [Re: Dragula] #2781441
06/04/20 05:07 PM
06/04/20 05:07 PM
birdtracker Offline
birdtracker  Offline
this should be really interesting. I would like to hear your bore and stroke thoughts. I did have a 4.375 stroke crank in a RB iron block with only a little grinding. Birdtracker
Re: 543 440 Combo's [Re: Dragula] #2781579
06/05/20 01:14 AM
06/05/20 01:14 AM
Which stock block, year and type, B, RB hemi
I wouldn't waste my time or money on using a girdle in any stock RB or B block twocents I do use aluminum main caps and ARP main suds on the 400 blocks I build if they sonic test good up scope
Buy a good block and have fun making a lot of power up
Re: 543 440 Combo's [Re: Dragula] #2781653
06/05/20 11:18 AM
06/05/20 11:18 AM
NC
440Jim Offline
440Jim  Offline
NC
Depends on power level.
Turning 2000 rpm on the street should not be a problem.
Making over 800 hp, I would want a better block. twocents
Re: 543 440 Combo's [Re: 440Jim] #2781774
06/05/20 02:51 PM
06/05/20 02:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I’m not sure which combo the “543” is.
4.375 x 4.500 is 541.2
4.380 x 4.500 is 542.4
4.500 x 4.250 is 540.7
4.440 x 4.375 is 541.9
Re: 543 440 Combo's [Re: fast68plymouth] #2781875
06/05/20 07:48 PM
06/05/20 07:48 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
I'll give this a bump as I will be building a new engine this winter and wondering if there 543 combo is better or use the 528 combo
Re: 543 440 Combo's [Re: dbran451] #2781885
06/05/20 08:24 PM
06/05/20 08:24 PM
Alberta
440_Offroader Online content
440_Offroader  Online Content
Alberta
I was just looking at the 440 source combo for my 4x4. Using the 24cc dish pistons were. 050" below deck. With milling the block deck that. 050", it would bump the compression from 9.5 to 10.3 with my 84cc heads. That's if you could get 4.350" pistons. All the pistons listed were. 055"+ os. Of course this is for a 4x4 and not a race engine, so I think it would be a good stump puller on pump gas. The girdle would probably be a good idea, even for what I'd be using it for. Just wasn't sure if I wanted to go that big, having to use external oil line. I'd be interested in seeing any combos with the 4.5" stroke, as well.
Re: 543 440 Combo's [Re: fast68plymouth] #2781898
06/05/20 09:10 PM
06/05/20 09:10 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You know Dwayne, I never could figure out what a 472 crate hemi was either.
4.25 x 4.150 = 470.9
Did "471" sound too much like a Ford product? Not sure what the logic was there.
We will never know. But I do remember the part number was P5249666.
As in "mark of the beast" if you believe such things LOL
Rich H.
Esse Quam Videri
Re: 543 440 Combo's [Re: ZIPPY] #2781925
06/05/20 10:07 PM
06/05/20 10:07 PM
Dragula Offline OP
Dragula  Offline OP
Just curious who has built one in a stock block, and how hard did you lean on it.....We have a ton of the 512 builds running around here. Fastest one was mine at 9.70 at 138.5mph on pump gas which my little 400/512 has eclipsed to a 9.60...We even have one of the 526 builds running real strong in my buddies car, so the obvious question is how would the 543 fair?
http://store.440source.com/Stroker-Kits/products/3/
440 >> 543. (4.500" stroke/7.100" rod)
Re: 543 440 Combo's [Re: Dragula] #2781995
06/06/20 08:27 AM
06/06/20 08:27 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well, here is another bump... I'd like to know just for info.
Rich H.
Esse Quam Videri
Re: 543 440 Combo's [Re: Dragula] #2782011
06/06/20 09:20 AM
06/06/20 09:20 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I'm still planning on doing one. 4.375x3.91, I have a 77 400 block I will be starting on soon. Not sure of the heads, but I would like to use the stage v conversion hemi head on this 470. Would have to find them second hand now that they no longer make them. This would be an interesting package because I see no one doing it. I like to be different, just as most go roller when I want to see want can be obtained with a SFT.
Re: 543 440 Combo's [Re: mopar dave] #2782144
06/06/20 02:31 PM
06/06/20 02:31 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
FWIW the 512" low deck in my Valiant went 9.0's at 150 NA. SO you can certainly can make some steam this way. Will it live a long happy life, mine sure didn't. It went 100ish passes before the block gave out. Yes it had aluminum caps. Im pretty sure the 900ish HP from an NA combo in a stock block was just to much for the ole gal. I don't really know the power as it was never on the dyno but went 150 at 3470lbs so 900ish. When I did it they were between iron blocks and didn't have the $$$ for aluminum. I learned my lesson and now choose better blocks, but they have their limitations too I suppose.
Re: 543 440 Combo's [Re: Al_Alguire] #2782145
06/06/20 02:34 PM
06/06/20 02:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My 470" tall deck went 9.69 at 139 in a 3100lb Duster with iron heads. It don't take a ton of power to run that in a typical A body racecar, 650ish will do it and I think they can live long happy lives at that level. Provided that the cylinders have some thickness or they have a tall fill.
Re: 543 440 Combo's [Re: Al_Alguire] #2782258
06/06/20 08:45 PM
06/06/20 08:45 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
That is a bunch of hp Al. What compression, cam and heads does it take to get 900hp?
Re: 543 440 Combo's [Re: Dragula] #2782278
06/06/20 10:31 PM
06/06/20 10:31 PM
gregsdart Offline
gregsdart  Offline
I like it for a high torque low rpm build. I raced a 4.5 stroke 4.350 bore motor many years ago. Very mild build that made enough power to go 10.20s at 129 mph in a 3400 lb duster. I ran 4.10 gears and 33 inch tall slicks. Since the block has about a 650 hp fuse on it, plan accordingly. The best part is it can make decent power at VERY low rpm allowing a long valvetrain and block life if rpm is kept low.
Re: 543 440 Combo's [Re: mopar dave] #2782395
06/07/20 01:35 PM
06/07/20 01:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I say 900ish because it was never on a dyno, just a garage build but I know the car went 150 at 3470. It was 15.5-1, CFE ported B1 heads. Cam I am not sure I have the info any longer but I recall was low .800" lift for sure(common shaft T&D's, would have been a split lift deal), duration sure was high 280ish/290 ish and on a 114-117 lobe center. I am sure I have the build notes just not sure where as we are getting ready to move. It would be typical for other B1 stuff I have done over the years, this was a very nice set of heads done by CFE. The heads ended up on another combo and made 1025 in a 572.
FWIW our 446 we ran in the dragster when my kid was a newbie was probably 650plus. Went 8.19 best here in Vegas at 1875lbs. Was a 12-1 compression deal with decent set of Indy -1's and a smallish roller on E85. Would have been in the 7's at sea level.
Re: 543 440 Combo's [Re: fast68plymouth] #2782963
06/08/20 06:09 PM
06/08/20 06:09 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
Our 543 kit is a 4.500 stroke x 4.380" bore, which equals 542.43 cubic inches. We offer pistons for that kit in .060" over, so we usually rate the cubic inches at the largest available bore size. And we did round up by .57 hundredths of a cubic inch.
Re: 543 440 Combo's [Re: 440sourcedotcom] #2782968
06/08/20 06:18 PM
06/08/20 06:18 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Which block do you recommend? Any consideration on the industrial 413,block ? What’s the minimum wall thickness? Do you offer an assembled short block ?
Re: 543 440 Combo's [Re: dOoC] #2783070
06/09/20 02:00 AM
06/09/20 02:00 AM
I've sonic tested 4 stock bore(4.180) 413 truck and industrial block, none of them would go safely above 4.250 bore size in my opinion shruggy
I like to have at least .160 wall thickness on both thrust surfaces after boring up work
Re: 543 440 Combo's [Re: Cab_Burge] #2783365
06/09/20 07:07 PM
06/09/20 07:07 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
I was looking at the eagle 540 kit, with only -8 cc dish pistons, it seems to really limit the head choice. What other heads have 88cc besides edelbrock that breathe enough for 540? I suppose the -8 is ok for a strip motor with hi octane fuel, not well suited for a street or 4x4 build running on pump swill.
Page 1 of 3 1 2 3
