Compressor wiring
#2782956
06/08/20 06:05 PM
06/08/20 06:05 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
I have a 220v compressor in my garage. It is up off the floor and plugged into an outlet in the ceiling. I turn it on/off with the breaker but I want to wire in a switch going to the plug. Will someone draw out a diagram of how I would wire in the switch?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Compressor wiring
[Re: dfsmopars]
#2782976
06/08/20 06:32 PM
06/08/20 06:32 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
[align:right][/align]I’m not techy enough to draw it here, but you need a double pole switch as you are simultaneously turning both legs on and off, just like you are currently doing with the breakers.
[Re: dfsmopars]
#2782979
06/08/20 06:46 PM
06/08/20 06:46 PM
Posts: 4,159 Canada -- Posts: 4034 -Registe...
5thAve
I have a 220v compressor in my garage. It is up off the floor and plugged into an outlet in the ceiling. I turn it on/off with the breaker but I want to wire in a switch going to the plug. Will someone draw out a diagram of how I would wire in the switch? Get a 240V non fused disconnect switch. Under $20 from Home Depot. It should show how to connect on it. Pretty much like this but imagine you're hooking up a compressor and not a water heater. http://waterheatertimer.org/How-to-wire-safety-switch.html
[Re: dfsmopars]
#2783018
06/08/20 08:37 PM
06/08/20 08:37 PM
Posts: 22,728 Bitopia
jcc
Bitopia
We really should know the compressor amperage here. One consideration, a compressor almost uniquely has huge start up current draws, meaning a typical rocker switch, will at some likely blow out is contacts after a number of starts under load. Better switches have a HP rating, but not sure if that takes into consideration a compressor type load. Stopping it with the switch when running also causes the contacts to arc slightly every time its turned off, again eroding the contacts. This is why "starters" are used in that the contact is quick, and forceful, and oversize. What you are doing will work, its not unsafe unless there are flammable vapors nearby, but will likely eventually fail. A safety tip when doing the actual work, always "act" like every wire is always electrically hot, meaning if you touch it, don't simultaneous touch anything else ( were/how you stand is important) ie the bird safely sitting on the power line concept. https://assets.gordonelectricsupply...VArSbvM813OeoUwHiIaTl0hdiuMaAn89EALw_wcBI'd guess #7832 is close to what is best solution for you, based on what little we know so far.
[Re: dfsmopars]
#2783032
06/08/20 09:36 PM
06/08/20 09:36 PM
dfsmopars
Kentucky
I’ll be back with more information tomorrow. The compressor was a plug and play from Home Depot.
[Re: dfsmopars]
#2783043
06/08/20 10:46 PM
06/08/20 10:46 PM
5thAve
Magnetic starter or anything with 120V contact is overkill for a home depot compressor. Some people only use the plug to turn their compressor on and off. Yes the manual motor starter switch that JCC linked to is the best way to go and it essentially would look like a surface mounted switch and it would wire up the same way as the previous diagram. Whats also important and what I should have asked before is how often is this compressor being turned off? I don't use mine regularely I've had it hooked up for years thru a non fused disconnect with no problem. I trust it more then the cheap switch compressors come with and circuit breakers aren't meant to be constantly turned on and off like that.
[Re: dfsmopars]
#2783328
06/09/20 05:27 PM
06/09/20 05:27 PM
dfsmopars
Kentucky
Motor is 15A single phase 240v.
[Re: AndyF]
#2783368
06/09/20 07:19 PM
06/09/20 07:19 PM
jcc
Bitopia
Electrically that should work fine, and cheap enough to replace yearly if and when it gives up. I could not make out a HP rating for the switch in the pic. I made a comment previously of the uniqueness of compressor start loads. To be clear, most "motors" do not start under full load. Some compressors have an unloading circuit on start up, that helps. Saws, fans, heaters, lights, etc do not have a huge start up current draw like a compressor does. Hard to believe this is same quality as a the Hubble stuff is, and of course it has to be made in China. And start up peak short term currents can easily be over double that of name plate ratings. So I'm slightly skeptical, but can't point to anything obviously wrong with this choice, based on what we know so far.
[Re: jcc]
#2783383
06/09/20 07:56 PM
06/09/20 07:56 PM
5thAve
Looks lke it's 2HP-240V. Either way should be OK and if not it's cheap to replace and the rough-in is already there if you want to replace it with something better.
[Re: dfsmopars]
#2783440
06/09/20 10:20 PM
06/09/20 10:20 PM
dfsmopars
Kentucky
Thanks. I’m good with the switch. Now the question is how do I go from the compressor simply being plugged in 12 feet from the floor and being controlled with the breaker to getting the the control in the switch at floor level. I know there are two hots going to the plug. What’s the best way to incorporate the switch? Do I ditch the plug and use the box as some type of junction box or do I use the switch to control the plug? If this was 120V I could do it by running the neutral down to the switch then back up to the plug. But I’m thinking 240V is not that simple. BTW I built and wired the entire garage (200A) and it passed a temporary inspection. That was several years ago and I’m trying to go back and finish up some things.
[Re: stumpy]
#2783511
06/10/20 05:34 AM
06/10/20 05:34 AM
dfsmopars
Kentucky
Seems to me it wouldn't be that expensive to have an electrician to correctly install your switch and remove the worry of an electrical fire. That is an option, but during these “unprecedented days” I find myself with more time and less income.
[Re: dfsmopars]
#2783552
06/10/20 09:24 AM
06/10/20 09:24 AM
jcc
Bitopia
I would suggest keeping the 6'(?) cord/plug on the compressor. You need to wire/conduit close to the compressor, install a box with the switch you choose, and then add a female outlet for the compressor's cord to plug into, I would add a pilot light of some fashion after the switch, it will have to be 240V wired between the two hot legs, or just use a single leg (120V), but that would require a neutral, do not be lulled into using the ground. Regardless, the compressor must have a proper ground. The post switch pilot light will help you not leaving the compressor on un attended. There are no stupid questions here, so ask, and safety first.
[Re: 5thAve]
#2783954
06/11/20 12:18 AM
06/11/20 12:18 AM
Posts: 1,757 Phila
PhillyRag
Phila
Magnetic starter or anything with 120V contact is overkill for a home depot compressor. Some people only use the plug to turn their compressor on and off. Yes the manual motor starter switch that JCC linked to is the best way to go and it essentially would look like a surface mounted switch and it would wire up the same way as the previous diagram. Whats also important and what I should have asked before is how often is this compressor being turned off? I don't use mine regularely I've had it hooked up for years thru a non fused disconnect with no problem. I trust it more then the cheap switch compressors come with and circuit breakers aren't meant to be constantly turned on and off like tha Nothing wrong with operating any breaker under load. They're designed for that & it does often "clean" the contacts[/color]t. Didn't it come with a pressure switch with an side lever switch? like in pic. Better ones do.[color:#33FF33][/color]
