Re: Engine/Trans Alignment
[Re: tabletop390]
#2782736
06/08/20 12:32 PM
06/08/20 12:32 PM
Posts: 287 PA
Harry's Taxi 2
PA
Not the best picture, but here's what I did. The dial indicator is mounted to the crank and indicates off of the o.d. of the trans oil pump register.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: John_Kunkel]
#2782745
06/08/20 12:47 PM
06/08/20 12:47 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
If you are running a 904 take this time to change the snout over to the later model A500 style. A&A sells pump gears to make the switch easy. If this was a 727 that is an unusual failure, very common for 904s though.
68 Barracuda Formula S 340
[Re: John_Kunkel]
#2782748
06/08/20 12:50 PM
06/08/20 12:50 PM
Posts: 287 PA
Harry's Taxi 2
PA
What kinda readings did you get? I don't recall exactly as it was a few years ago....around .017-.019? too low (the trans.) and it was also a little off left to right. I checked it because the block was line honed, but being off left to right says I should have been and will be checking all from now on if possible.
[Re: tabletop390]
#2782796
06/08/20 01:52 PM
06/08/20 01:52 PM
Bad340fish
Tulsa OK
It's from a 727 small block. Converter was a TCI 8" that was rebuilt by PTC a few years ago. Flexplate is a B&M. It's kinda hard to see in the picture I posted, but the weld is cracked as well. I did pressure check the converter and it is pushing air out. Wow I can't say I have ever heard of that happening to a 727
[Re: tabletop390]
#2782944
06/08/20 05:44 PM
06/08/20 05:44 PM
Posts: 287 PA
Harry's Taxi 2
PA
What offset dowels did you use Harry? Or did you have them made? http://www.robbmcperformance.com/products/dowels.html These are what I used....they are pretty easy to adjust. There are some Lakewood ones that are less expensive and almost fit (.006 larger diameter), but don't waste your money on them. I did and thought I could do a little sanding to get them to fit....I did get them to fit in the block, but there really isn't any way to rotate them to get your alignment without ruining them.
[Re: Harry's Taxi 2]
#2783100
06/09/20 09:11 AM
06/09/20 09:11 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
What offset dowels did you use Harry? Or did you have them made? http://www.robbmcperformance.com/products/dowels.html These are what I used....they are pretty easy to adjust. There are some Lakewood ones that are less expensive and almost fit (.006 larger diameter), but don't waste your money on them. I did and thought I could do a little sanding to get them to fit....I did get them to fit in the block, but there really isn't any way to rotate them to get your alignment without ruining them. I ended up getting some from summit .014 and .021" and I filed the engine side to fit but still move and you have an allen socket to move the offset even with the trans on.I get summit delivered in 1 day so it made it easy/fast but rob may be the choice for most people.
[Re: tabletop390]
#2783168
06/09/20 11:44 AM
06/09/20 11:44 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I had a crack form starting at the bottom corner of the input sleeve notches on my '68 trans. Sent it in and they welded in a new one with a smoother radius at that location.
Great tips on measuring the run-out using the transmission case, but be sure to ensure the case is square to the block/crank flange too. A lot of people overlook this step, but my '70 manual trans car was off enough to use shims to get it squared up.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
