torqueflite pan gasket #2782476
06/07/20 05:50 PM
06/07/20 05:50 PM
usa
lewtot184 Offline OP
usa
I've been using the mopar black (reuseable?, but I never re-use them) gaskets for years, and for years they always weep, drip, or leak. what's a better gasket that will keep things dry?
Re: torqueflite pan gasket [Re: lewtot184] #2782493
06/07/20 07:00 PM
06/07/20 07:00 PM
AndyF Offline
AndyF  Offline
Good question. I have the Mopar gasket on the 727 in my Duster and it has also always weeped a little bit. There is always a drip or two under the car. It doesn't actually leak, it just weeps enough to coat the surface of the pan then once in awhile a drop forms and lands on the floor. About one drop a day. I'm going to try a different gasket too. I'm thinking I'll try the Moroso soft rubber one to see if it seals better with the Moroso aluminum pan that I have.
Re: torqueflite pan gasket [Re: AndyF] #2782509
06/07/20 07:34 PM
06/07/20 07:34 PM
usa
usa
i'll take a look at the moroso. I don't think your suppose to rtv the gaskets; been using hi-tack.
Re: torqueflite pan gasket [Re: lewtot184] #2782515
06/07/20 07:58 PM
06/07/20 07:58 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Hi-Tack has been our choice on the majority of gaskets on our engines and trans.
I've found if you have pans (aftermarket) that have flat rails, your incidence
of leaks is greatly diminished.
Joe
Re: torqueflite pan gasket [Re: lewtot184] #2782516
06/07/20 07:58 PM
06/07/20 07:58 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I reuse the black Mopar one, I have had the pan off & on about 5 times on my A518, dry as can be,
Re: torqueflite pan gasket [Re: lewtot184] #2782530
06/07/20 08:27 PM
06/07/20 08:27 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I've had best luck with Moroso blue rubber with steel core. Fits in all the machining marks and let's you really tighten it down. Just make sure your pan bolts or studs are long enough because it's quite thick.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: torqueflite pan gasket [Re: A39Coronet] #2782533
06/07/20 08:35 PM
06/07/20 08:35 PM
A727Tflite Online content
A727Tflite  Online Content
The black reuseable Mopar production gasket has torque limiters built in, you can’t overtighten the gasket.
If you truly have a wet pan gasket you either have a leak from something/somewhere else or your pan is not perfectly flat.
Don’t use any sealer on this gasket, it’s not needed.
Re: torqueflite pan gasket [Re: A727Tflite] #2782548
06/07/20 09:30 PM
06/07/20 09:30 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Might be a bad front seal or pump bushing. Those oem gaskets are pretty good. work
Re: torqueflite pan gasket [Re: bobby66] #2782631
06/08/20 08:00 AM
06/08/20 08:00 AM
usa
usa
I've been thru the cooling lines, valve body seal stuff; etc, it's the pan. I hate going thru a trail and error process with this because it's so messy. when these tranny's were new they had simple cork gaskets and didn't leak all over the place for many miles. maybe we take a simple solution and make it difficult?
Re: torqueflite pan gasket [Re: lewtot184] #2782645
06/08/20 09:12 AM
06/08/20 09:12 AM
All gasket styles require a flat pan flange.
I’m betting if you take the pan off and lay it on a flat surface you will see out of flat areas, belled bolt hole, etc.
The reason we went from cork to the reuseable was the cork weeped after being in service because it lost compression from shrinkage.
All our warranty pretty much dried up after doing that, pun intended.
Re: torqueflite pan gasket [Re: lewtot184] #2782646
06/08/20 09:12 AM
06/08/20 09:12 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I never had any luck with that gasket. I just use the black rubber gasket that comes with the filter from Advance Auto, no weeping.
Re: torqueflite pan gasket [Re: justinp61] #2782649
06/08/20 09:46 AM
06/08/20 09:46 AM
usa
usa
are the bolt holes for the pan blind holes? I haven't had either trans pan off in a couple of years and don't remember.
Re: torqueflite pan gasket [Re: A727Tflite] #2782650
06/08/20 09:49 AM
06/08/20 09:49 AM
usa
usa
checking for a flat gasket surface will be done. I use the mopar deep pans and i'm careful about over torqueing. using a cast alum pan may hang down a little further than I want but i'll measure for that option.
Re: torqueflite pan gasket [Re: lewtot184] #2782660
06/08/20 10:20 AM
06/08/20 10:20 AM
X3 on confirming flat rails & as you know side to side torquing & not overtight
Re: torqueflite pan gasket [Re: RapidRobert] #2782666
06/08/20 10:34 AM
06/08/20 10:34 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
BECAUSE of the PUCKERED pan rails ... I’ve found in the past to just go with a cast aluminum pan
Re: torqueflite pan gasket [Re: lewtot184] #2782743
06/08/20 12:41 PM
06/08/20 12:41 PM
Some are blind and some are not.
Someone else said they were never lucky using this gasket.
Sealing the pan up is not about luck, it’s about being thorough.
It’s been a while since I ran a study at work, but if I recall the pan flange has to be flat within .013”. That means you cannot insert a .013” feeler gauge between the flange and flat surface.
The most common issue with stamped steel pans is when someone has “bell mouthed” the bolt hole areas in the pan.
That usually happens when someone tried to seal the pan up by over torquing the bolts when using a cork or composite gasket.
Again, you can’t over tighten the reuseable gasket because the plastic backbone prevents that. You will strip the case bolts before that happens.
Re: torqueflite pan gasket [Re: A727Tflite] #2782753
06/08/20 01:02 PM
06/08/20 01:02 PM
usa
usa
thanks
Re: torqueflite pan gasket [Re: lewtot184] #2782784
06/08/20 01:31 PM
06/08/20 01:31 PM
5thAve Offline
5thAve  Offline
I use the reusable mopar one when I drop my pans and never had a problem. The parts guy at the dealer didn't even need the part number. Every time I've gotten one I walked in and told them what I was after and even saying 727 he walked back and grabbed it without even looking it up.
Re: torqueflite pan gasket [Re: 5thAve] #2782791
06/08/20 01:44 PM
06/08/20 01:44 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
FIFTH ... you should have bought a FIFTH of them on eBay to start with! ... coffee
Re: torqueflite pan gasket [Re: A727Tflite] #2783426
06/09/20 09:45 PM
06/09/20 09:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I’ve reused the one n my 47RE at least four times. I’ve also reused the one on my 727 w/t 47RE pan several times. 125 inch lbs.... no leaks ever! Lucky me!!
That gasket and the chevy style umbrella seal for the dipstick tube were great advancements in torqueflight sealing
