Carburetor mounting #2780915
06/02/20 10:07 PM
06/02/20 10:07 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
What is the correct mounting hardware for a 74 small block four barrel and a 71 big block four barrel, bolts or studs?
Re: Carburetor mounting [Re: 340cpe] #2781209
06/03/20 08:48 PM
06/03/20 08:48 PM
WV
Little Detroit Offline
WV
if you want OEM correct fasteners littledetroitrestorations.com the absolute largest selection of All OEM Correct made in the USA fasteners.
Re: Carburetor mounting [Re: Little Detroit] #2781253
06/03/20 10:57 PM
06/03/20 10:57 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank You I have seen both bolts and studs and not sure which was correct, maybe both are! What ever was available when engine was being assembled.
Re: Carburetor mounting [Re: 340cpe] #2781332
06/04/20 10:28 AM
06/04/20 10:28 AM
WV
WV
studs on 4 bbl application , bolts on multi carb applications
Re: Carburetor mounting [Re: Little Detroit] #2782026
06/06/20 09:54 AM
06/06/20 09:54 AM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Thank You!!
Re: Carburetor mounting [Re: Little Detroit] #2782130
06/06/20 01:55 PM
06/06/20 01:55 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
That isn't true at all!
Your saying all 4bbl. applications???
Ron
Re: Carburetor mounting [Re: RJS] #2782217
06/06/20 06:30 PM
06/06/20 06:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I was think 1971 V8 4 bbl applications were bolts. ?
I know for sure some 318 2barrel applications were 2 studs/nuts and 2 bolts
Re: Carburetor mounting [Re: gtx6970] #2782294
06/06/20 11:54 PM
06/06/20 11:54 PM
WV
WV
you guys should really pay attention to the question asked ,instead of trying to stir things up. that's exactly why this site is losing patrons
Re: Carburetor mounting [Re: 340cpe] #2782327
06/07/20 08:57 AM
06/07/20 08:57 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Here's the part of question asked above. Your answer was studs: for 71 big block four barrel.
How is that correct?????
How am I stirring things up?
Ron
Re: Carburetor mounting [Re: gtx6970] #2782349
06/07/20 11:07 AM
06/07/20 11:07 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
iagree Almost certain '67 ~ '71. Not sure about '72, only had one for a very short time.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Carburetor mounting [Re: 3hundred] #2782532
06/07/20 08:33 PM
06/07/20 08:33 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
It's bolts on bigblocks right up to 72, never really cared to investigate later cars.
Ron
Re: Carburetor mounting [Re: RJS] #2782585
06/07/20 11:19 PM
06/07/20 11:19 PM
WV
WV
I really hate the taste of crow .. I was wrong .. doesn't matter why imis spoke no excuse for it . correct is bolts up to 74 .
Re: Carburetor mounting [Re: Little Detroit] #2782630
06/08/20 07:51 AM
06/08/20 07:51 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
No biggie Little Detroit, we've all had that taste once or twice.....LOL
Joe
Re: Carburetor mounting [Re: jlatessa] #2783454
06/09/20 10:51 PM
06/09/20 10:51 PM
Pa.
3
340cpe Offline OP
340cpe  Offline OP
Pa.
Great so it’s bolts on big blocks but how about the small block?
Re: Carburetor mounting [Re: 340cpe] #2783533
06/10/20 07:59 AM
06/10/20 07:59 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Now I'm out on a limb, but I think 4bbls are bolts, 2bbls are studs, again limited to years you listed earlier. Kinda anxious to see what the small block guys say.
'69 300 Convertible
'16 300 S Hemi
Re: Carburetor mounting [Re: 3hundred] #2783785
06/10/20 04:52 PM
06/10/20 04:52 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Everybody slow down and read the questions before answering. I’ve read the answers and some are wrong.
Have to tell you that 1967 BB mopars With 4bbl are studs and nuts. Owned multi-dozens of these cars.
Friend bought a 67 GTX new and still owns it, very original car That is a great reference. Studs and nuts.
I know 1970 and 1971 are bolts only
I feel they changed to bolts in 1970 when the chokes and intakes changed and they started using the think carburetor base gaskets.
Same intake Manifold 1967-1969. Same hardware?
Re: Carburetor mounting [Re: 340cpe] #2783800
06/10/20 05:39 PM
06/10/20 05:39 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1968 model year 440 intake with carburetor studs and bolts;
