header gasket/ collector gasket #2780104
05/31/20 04:55 PM
05/31/20 04:55 PM
Can , Nova Scotia , Cape Breto...
caper Offline OP
caper  Offline OP
Who makes/sells a good quality header gasket for TTI headers 440 base engine part# please, RPM heads and 3 1/2 collector gasket.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: header gasket/ collector gasket [Re: caper] #2780118
05/31/20 05:34 PM
05/31/20 05:34 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I use the Trickflow header gasket ,MLS style steel/aluminium ?
I use ebay copper coleector gaskets
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: header gasket/ collector gasket [Re: caper] #2780131
05/31/20 06:31 PM
05/31/20 06:31 PM
Mr. Gasket ultra work really well for me up scope
Re: header gasket/ collector gasket [Re: Cab_Burge] #2780139
05/31/20 06:44 PM
05/31/20 06:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I don’t know the part number but I bought copper collector Gaskets from Summit years ago and they are still going strong on my Duster.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: header gasket/ collector gasket [Re: caper] #2780177
05/31/20 08:38 PM
05/31/20 08:38 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I like reflex, best header gasket I ever used. As mentioned copper is good for collectors.
Re: header gasket/ collector gasket [Re: rickraw] #2780206
05/31/20 10:02 PM
05/31/20 10:02 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
I second RicRaw on the Remflex gaskets. I have them on my wedge running hookers and Eddy Performer RPM heads. No leaks and lots of crush. Supposed to be reusable but I haven't tried that yet. They are pretty thick (~0.250") so if your fit is really tight, they might make things worse.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: header gasket/ collector gasket [Re: caper] #2780338
06/01/20 01:48 PM
06/01/20 01:48 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Regardless what brand, consider this:
Fiber only = very conformable but short life
Fiber-faced over perforated metal = conformable with long life
metal faced (flat of MLS): not very conformable for sealing; will last very long
I'm a former gasket engineer from a major company.
Re: header gasket/ collector gasket [Re: caper] #2780343
06/01/20 02:06 PM
06/01/20 02:06 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I buy the TTI Gaskets, they are the best exhaust gaskets I have ever dealt with.
68 Barracuda Formula S 340
Re: header gasket/ collector gasket [Re: Bad340fish] #2780381
06/01/20 03:44 PM
06/01/20 03:44 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Only times I've had exhaust gasket problems, the actual cause was trying to seal mis-matched or warped surfaces.
Re: header gasket/ collector gasket [Re: topside] #2780386
06/01/20 04:03 PM
06/01/20 04:03 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
I agree with this. The other problem I've run into is bolts loosening. Locking header bolts are wonderful. That or safety wire. Also I've used wire connector star washers under the bolt head and nut.
Re: header gasket/ collector gasket [Re: MoonshineMattK] #2780390
06/01/20 04:14 PM
06/01/20 04:14 PM
PA.
"Little"John
"Little"John
PA.
Don’t you just love these guys that start a post and disappear.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: header gasket/ collector gasket [Re: pittsburghracer] #2780395
06/01/20 04:30 PM
06/01/20 04:30 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
I’ve used dead soft pure copper gaskets on headers and iron manifolds up
Re: header gasket/ collector gasket [Re: pittsburghracer] #2780396
06/01/20 04:32 PM
06/01/20 04:32 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Any gasket with a thin skim of copper rtv works great. Copper rtv and copper gaskets is bulletprofof and reusable. Just wire brush it off and re-apply the rtv each time you need to take it apart. My brother got this idea from some fuel altered guys who came here years ago as that is what they did with their race car.
Re: header gasket/ collector gasket [Re: Neil] #2780504
06/01/20 08:18 PM
06/01/20 08:18 PM
caper Offline OP
caper  Offline OP
I didn't disappear, I had a very busy day. I picked a set of Fel-pro 1414 locally. and Mr gasket 3 1/2 collector gasket. I will put some high heat silicone on them. I will order the remflex gasket. Thanks guys, sorry for getting back late.
Re: header gasket/ collector gasket [Re: caper] #2781175
06/03/20 06:43 PM
06/03/20 06:43 PM
Mopar Mitch Offline
Mopar Mitch  Offline
There is no need for any silicone to be placed onto the fiber-faced gaskets... in fact, the Fel-pro gaskets have Teflon anti-stick coating applied so that they will not stick... and favors re-usage. The fiber facing will conform as long as there isn't a lot of warpage (as any gasket always wants flat straight surfaces to seal properly).
