Edm hydraulic lifter,with pushrod oiling #2780243
06/01/20 05:39 AM
06/01/20 05:39 AM
St.Louis ,Mo.
72sat Offline OP
72sat  Offline OP
St.Louis ,Mo.
Does anyone make one for a bb mopar
Re: Edm hydraulic lifter,with pushrod oiling [Re: 72sat] #2780255
06/01/20 08:04 AM
06/01/20 08:04 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Call Howards cams
Re: Edm hydraulic lifter,with pushrod oiling [Re: 72sat] #2780330
06/01/20 01:00 PM
06/01/20 01:00 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you have more than .0010 lifter to lifter bore clearances, most of the ones I've measured are all over .0025 shock, you don't need EDM oiling for that block or camshaft twocents
Use the money you save from that on some other better part up work
Re: Edm hydraulic lifter,with pushrod oiling [Re: Cab_Burge] #2782819
06/08/20 02:29 PM
06/08/20 02:29 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run the Comp solid flat tappet EDM lifters and they have the hole at the top where the pushrod goes if you want to use hollow pushrods for oiling. I do not use it as I just use the stock valvetrain oiling and my solid pushrods plug the lifter hole. Ron
Re: Edm hydraulic lifter,with pushrod oiling [Re: 383man] #2782873
06/08/20 04:04 PM
06/08/20 04:04 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
It’s hard for a hydraulic lifter to function properly when there is a .020” hole in the bottom of it, leaking oil out.
Get some Crower Camsaver lifters for an AMC v8.
Those will have added oil to the cam and pushrod oiling.
Re: Edm hydraulic lifter,with pushrod oiling [Re: CSK] #2783021
06/08/20 08:49 PM
06/08/20 08:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Originally Posted by csk
Call Howards cams
I have Howard's solid EDM lifters in my car and they are AMC type lifters with pushrod oiling. They were a good lifter and I only lost about 10 PSI oil pressure but I think it's a good trade off putting the oil where it needs to go when idling on the street.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Edm hydraulic lifter,with pushrod oiling [Re: fourgearsavoy] #2783058
06/09/20 12:08 AM
06/09/20 12:08 AM
Memphis,TN
J. Hammer Offline
J. Hammer  Offline
Memphis,TN
Edm hyd lifters folks. Someone have experience with those?
Re: Edm hydraulic lifter,with pushrod oiling [Re: J. Hammer] #2783245
06/09/20 02:27 PM
06/09/20 02:27 PM
So. Burlington, Vt.
So. Burlington, Vt.
See my previous post.
Or better yet....... post a part number for the lifters you’re asking about people’s experiences with.
Re: Edm hydraulic lifter,with pushrod oiling [Re: fast68plymouth] #2783309
06/09/20 04:29 PM
06/09/20 04:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
if the hole in the hydraulic tappet is underneath the tappet oil reservoir (which a hydraulic tappet has to have and maintain) and it's "constantly" leaking how's it supposed to work? wouldn't the tappet collapse everytime the engine is shut off? just asking.
Re: Edm hydraulic lifter,with pushrod oiling [Re: lewtot184] #2783599
06/10/20 11:16 AM
06/10/20 11:16 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just noticed I did not pay attention to the "Hydraulic" part of the caption. Sorry as mine are solids of course. Ron
