header gasket/ collector gasket
#2780104
05/31/20 04:55 PM
05/31/20 04:55 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
Who makes/sells a good quality header gasket for TTI headers 440 base engine part# please, RPM heads and 3 1/2 collector gasket.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: header gasket/ collector gasket
[Re: caper]
#2780118
05/31/20 05:34 PM
05/31/20 05:34 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I use the Trickflow header gasket ,MLS style steel/aluminium ? I use ebay copper coleector gaskets
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Cab_Burge]
#2780139
05/31/20 06:44 PM
05/31/20 06:44 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I don’t know the part number but I bought copper collector Gaskets from Summit years ago and they are still going strong on my Duster.
[Re: rickraw]
#2780206
05/31/20 10:02 PM
05/31/20 10:02 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I second RicRaw on the Remflex gaskets. I have them on my wedge running hookers and Eddy Performer RPM heads. No leaks and lots of crush. Supposed to be reusable but I haven't tried that yet. They are pretty thick (~0.250") so if your fit is really tight, they might make things worse.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: caper]
#2780338
06/01/20 01:48 PM
06/01/20 01:48 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Regardless what brand, consider this:
Fiber only = very conformable but short life Fiber-faced over perforated metal = conformable with long life metal faced (flat of MLS): not very conformable for sealing; will last very long
I'm a former gasket engineer from a major company.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: caper]
#2780343
06/01/20 02:06 PM
06/01/20 02:06 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I buy the TTI Gaskets, they are the best exhaust gaskets I have ever dealt with.
68 Barracuda Formula S 340
[Re: topside]
#2780386
06/01/20 04:03 PM
06/01/20 04:03 PM
Posts: 288 NW Illinois
MoonshineMattK
NW Illinois
Only times I've had exhaust gasket problems, the actual cause was trying to seal mis-matched or warped surfaces. I agree with this. The other problem I've run into is bolts loosening. Locking header bolts are wonderful. That or safety wire. Also I've used wire connector star washers under the bolt head and nut.
[Re: MoonshineMattK]
#2780390
06/01/20 04:14 PM
06/01/20 04:14 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don’t you just love these guys that start a post and disappear.
[Re: Neil]
#2780504
06/01/20 08:18 PM
06/01/20 08:18 PM
caper
I didn't disappear, I had a very busy day. I picked a set of Fel-pro 1414 locally. and Mr gasket 3 1/2 collector gasket. I will put some high heat silicone on them. I will order the remflex gasket. Thanks guys, sorry for getting back late.
[Re: caper]
#2781175
06/03/20 06:43 PM
06/03/20 06:43 PM
Mopar Mitch
There is no need for any silicone to be placed onto the fiber-faced gaskets... in fact, the Fel-pro gaskets have Teflon anti-stick coating applied so that they will not stick... and favors re-usage. The fiber facing will conform as long as there isn't a lot of warpage (as any gasket always wants flat straight surfaces to seal properly).
Mopar Mitch
