Koni shocks on sale #2778571
05/27/20 12:45 AM
05/27/20 12:45 AM
AndyF Offline OP
AndyF  Offline OP
The Koni 80-1538 front shock that fits A, B and E body cars is on sale now. Summit has them for $94 each. They are usually around $120. This is compared to the $140 price that I last saw for the Bilstein shocks. I just installed a set of Koni shocks on my Duster and they made an immediate improvement in the ride quality and handling. If you haven't installed these before beware of the large upper rubber bushing. Some rubber grommet lube is highly recommended to get it installed properly. It is an odd design that doesn't look like it will work but with some bushing lube it does actually go together. The Koni shocks are adjustable so if you aren't familiar with them you should read the instructions on line. You have to collapse the shock and then push it in gently while you turn the shock and then it will drop into an adjustment notch.
Re: Koni shocks on sale [Re: AndyF] #2778639
05/27/20 10:17 AM
05/27/20 10:17 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Are those the same ones you have on your 65?
Carl Kessel
Re: Koni shocks on sale [Re: CKessel] #2778676
05/27/20 11:44 AM
05/27/20 11:44 AM
AndyF Offline OP
AndyF  Offline OP
Yes. I have the same Koni front shocks on both the Duster and the Coronet.
Re: Koni shocks on sale [Re: AndyF] #2791796
07/02/20 08:29 AM
07/02/20 08:29 AM
New York
N
nialcoxworth Offline
N
New York
Re: Koni shocks on sale [Re: nialcoxworth] #2792149
07/03/20 12:10 AM
07/03/20 12:10 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I was always put off by the Koni adjustment method/easibility, but I have never owned a set, has it improved or is the inconvenience not what it seems to be? Other brand adjustable shock offerings are fairly simple IMO.
Re: Koni shocks on sale [Re: AndyF] #2803925
08/01/20 08:09 PM
08/01/20 08:09 PM
Canada
jerry9 Offline
jerry9  Offline
Canada
really nice setup , coud I use Koni shocks out back with my QA-1 single adjustable shocks in front ? A body with front and rear Hotchkiss hollow sway bars .
Re: Koni shocks on sale [Re: jerry9] #2805789
08/06/20 02:59 PM
08/06/20 02:59 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Above is the past typical way to adjust Koni shocks.. a hassle but the only way... at least with my old RED D Konis.
I'm looking forward to adjusting my new QA1 double adjustable shocks... by simply turning the knobs... once I start driving the car soon this summer.
Re: Koni shocks on sale [Re: Mopar Mitch] #2908047
04/08/21 02:54 PM
04/08/21 02:54 PM
Chicago, IL
P
PLUM_72 Offline
PLUM_72  Offline
P
Chicago, IL
I know this is an old post, but the shocks are still priced well. I'm new to adjusting shocks, and frankly would adjust them once and never again for the street. How do you know what's right with the adjustment? Is there a start point and refine from there, or is there a known spot to hit?
1972 Dodge Challenger
Re: Koni shocks on sale [Re: PLUM_72] #2908361
04/09/21 10:48 AM
04/09/21 10:48 AM
Mopar Mitch Offline
Mopar Mitch  Offline
Regardless of whichever brand adjustable shock you have, you have to determine the ride/performance that you feel is what you're looking for. Are you driving over bumpy roads or smooth roads? Do you want improved handling by keeping the car flatter? Rise/dive? Spirited/aggressive driving or gandma driving? I made multiple changes on my old Konis until I settled for my type of driving intentions. It was a little work... repeatedly and time consuming... but worth it. I ultimately settled on the fronts at full-stiff... and the rears at about 2/3 full stiff (any stiffer at the rears and the inside rear tires would lift off the ground when seriously autocrossing at hi-g-force).
I've recently replaced my front Konis with QA1 double-adjustables... quick and easy to adjust with knobs.... currently set at 50/50... but I'll be changing that this summer as I drive and race the car some more... some other similar cars/drivers have told me they run the fronts (QA1, Viking, etc dbl-adj) at 100% full stiff)... we'll see what suites me best after more experience at the tracks. Advantage of quick knob-type adjustable shocks is that you can change them per driving... street/hwy... then track... and back again.
Re: Koni shocks on sale [Re: PLUM_72] #2908556
04/09/21 11:00 PM
04/09/21 11:00 PM
AndyF Offline OP
AndyF  Offline OP
I put them in the middle of the range and just leave it there. But I'm just doing normal street driving, no hard core corner carving.
Re: Koni shocks on sale [Re: PLUM_72] #2910080
04/14/21 01:33 PM
04/14/21 01:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It really depends on the individual shock valving. We use a more drag oriented Viking Crusader shock but they are valve way stiffer than most to control a radial on a prepped surface.
Probably best to either call the manufacturer or have them send you a chart/pdf of recommended settings. Mine came with a chart.
'63 Dodge 330
11.19 @ 121 mph
Re: Koni shocks on sale [Re: PLUM_72] #2929179
06/01/21 02:10 PM
06/01/21 02:10 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've got a complete set of these on my Diplomat coupe. I don't think these particular part numbers are made anymore (FRONT = 80-2289, REAR = 80-2340), but I absolutely love these things.
The adjustment is a bit of a PITA, and if you really want to tune your suspension expect to have to at least take them apart a couple of times trying to dial them in. But...once the trial'n'error is done, sweet ride!
Here are the adjustment instructions that are a scan of the printed notes which came with my shocks. Maybe the newer ones have changed since, not sure, but this sounds awefully like what everyone else is talking about.
Re: Koni shocks on sale [Re: Diplomat360] #2929429
06/02/21 10:58 AM
06/02/21 10:58 AM
Knoxville, TN
Y
YGBSM Offline
YGBSM  Offline
Y
Knoxville, TN
Thinking about picking up a set. I'm used to Koni Yellows that are externally adjustable; removing the shocks to make adjustments is something I would prefer not to do.
So what are some good initial settings for a ride/handling compromise? Does Koni provide some recommendations?
1968 Charger R/T
2015 Charger R/T Scat Pack
2017 Durango Citadel
Re: Koni shocks on sale [Re: YGBSM] #2929486
06/02/21 01:25 PM
06/02/21 01:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not proud of it, but if I can't make the adjustment often and easy, I'll pass, and pun intended, and likely get passed. grin
Re: Koni shocks on sale [Re: jcc] #2929558
06/02/21 05:38 PM
06/02/21 05:38 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I had a set of Koni Yellow on my BMW M5. The fronts adjusted with a knob, but the rears had to be removed from the car which was a PITA on the M5 with rear sun shade. BUT, once adjusted properly, they were a big improvement over stock. On a Mopar, as easy as the rear shocks are to remove, I wouldn't think twice if the price was right, but I'm leaning towards double adjustable Vikings for my 'Cuda.
Re: Koni shocks on sale [Re: nialcoxworth] #2929821
06/03/21 04:52 PM
06/03/21 04:52 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
That's what she said.
Re: Koni shocks on sale [Re: YGBSM] #2929830
06/03/21 05:09 PM
06/03/21 05:09 PM
AndyF Offline OP
AndyF  Offline OP
Put them in the middle of the range and see if you like it.
Re: Koni shocks on sale [Re: AndyF] #2929835
06/03/21 05:28 PM
06/03/21 05:28 PM
Knoxville, TN
Y
YGBSM Offline
YGBSM  Offline
Y
Knoxville, TN
Thanks Andy. I've got both your books and have read your articles in Mopar Action and Hot Rod. I appreciate all you do for this hobby.
1968 Charger R/T
Re: Koni shocks on sale [Re: YGBSM] #2930672
06/06/21 10:36 PM
06/06/21 10:36 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I took the Savoy out for a long drive Saturday and I'm thinking of getting a set of these Koni shocks for the front. The long drive with the KYB shocks feeling every crack in the freeway was annoying after about 30 minutes. The Summit near me has them in stock so I'll pick them up on the way home tomorrow.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Koni shocks on sale [Re: fourgearsavoy] #2941987
07/11/21 10:34 AM
07/11/21 10:34 AM
Knoxville, TN
Y
YGBSM Offline
YGBSM  Offline
Y
Knoxville, TN
So reading other threads on the Konis, some people complained the rear shocks are too short and the lower bushing is too small. What's the story? Has this been corrected on current production??
1968 Charger R/T
