TRANS TEMP T-FITTING ADAPTER #2778416
05/26/20 04:45 PM
05/26/20 04:45 PM
NW Chicago suburban area
Mopar Mitch Offline OP
Has anyone installed a Glow Shift T-fitting (5/16") into their trans line? pictures? best location? wiring from sensor?
I'm getting ready to install a trans temp gauge and I'm debating the T-fitting location. I do have a remote cooler in front of the radiator (by-passing the factory radiator cooler.. new US Radiator aluminum triple flow radiator doesn't have a trans cooler).
I can't use a deep pan because my car sits low and it'll hit the ground. The only deeper pan vs stock would be the Moroso 42080 as its about 1" shallower than the typical deep pan... measures at 2-5/16" plus gasket thickness. That Moroso pan has two front plugs.. could possibly fit a sensor into one of the plugs.
Comments appreciated.
Re: TRANS TEMP T-FITTING ADAPTER [Re: Mopar Mitch] #2778420
05/26/20 04:52 PM
05/26/20 04:52 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
727 or 904? The factory 518's and 500's used a deep stamped steel pan. Have you measured how low one of those would hang?
Re: TRANS TEMP T-FITTING ADAPTER [Re: burdar] #2778424
05/26/20 05:05 PM
05/26/20 05:05 PM
newly built 727... small block 410 stroker... used for AX, HSAX, HPDE road course racing (lapping sessions)
Also, as I've used a common deep (~3-3.5" pan in the past)... then oil will run up and spill out of the dip stick upon hard g-force left-hand deceleration/sweeping turns, etc... wish the pan could be baffled... a locking dip stick is also used,,, but the g-forces are high in my racing conditions, so, the less fluid stock pan has proven the better route... I'm only considering the Moroso 42080 pan because it's shallower than most deep pans.
Re: TRANS TEMP T-FITTING ADAPTER [Re: burdar] #2778479
05/26/20 07:27 PM
05/26/20 07:27 PM
BDW Offline
BDW  Offline
Moroso pan looks nice, but $250?
I’m using Dorman 265-827 on my 518, 2.75” deep and only $40
Re: TRANS TEMP T-FITTING ADAPTER [Re: Mopar Mitch] #2778490
05/26/20 08:13 PM
05/26/20 08:13 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Make it simple and weld one of these into the side of your pan.
Bung
Re: TRANS TEMP T-FITTING ADAPTER [Re: Mopar Mitch] #2778497
05/26/20 08:26 PM
05/26/20 08:26 PM
I've welded in bungs into tranny pans as well as tap aluminum tranny pan bosses for the temp. senders.
I saw a post on the CTD site years ago about installing the sender in the front servo (there is a NPT plug at the top to use for pressure readings, install it (electrical senders) in that hole scope up) on the early (1998) automatic O.D. tranny in the CTD trucks, I switch mine after that and saw no differences in the readings shock
That's where I install mine now up
My thinking is you want to know the temps of the fluids circulating through the tranny, not going or returning from the cooler work
Re: TRANS TEMP T-FITTING ADAPTER [Re: Mopar Mitch] #2778519
05/26/20 09:21 PM
05/26/20 09:21 PM
AndyF Online content
AndyF  Online Content
I use the Moroso pan in my Duster with a temp sensor in the port.
Re: TRANS TEMP T-FITTING ADAPTER [Re: Mopar Mitch] #2778531
05/26/20 09:40 PM
05/26/20 09:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I got the brass fittings all for under 20$ or soand placed it under the starter and hang it off the oil pan with a long stud.
ps:sorry I see you run hard line but you can buy a fitting to adapt to that for my tee.
Re: TRANS TEMP T-FITTING ADAPTER [Re: Clanton] #2778606
05/27/20 08:54 AM
05/27/20 08:54 AM
RWG75
RWG75
I've always used what I think is a factory port for pressure testing. Sensor that comes with Auto Meter gauge threads right in. Recall this being on the advise of an old time trans guy.
Re: TRANS TEMP T-FITTING ADAPTER [Re: Mopar Mitch] #2778608
05/27/20 09:07 AM
05/27/20 09:07 AM
Central Mississippi
mopar97 Offline
mopar97  Offline
Central Mississippi
Mine is located at the front trans line outlet on the transmission.
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: TRANS TEMP T-FITTING ADAPTER [Re: Mopar Mitch] #2778661
05/27/20 11:06 AM
05/27/20 11:06 AM
A727Tflite Offline
A727Tflite  Offline
Best location?
Depends what you want to actually determine.
The front cooler line fitting is trans “out”, comes right from the converter and will be the hottest.
The rear fitting is “cooler return” and will naturally be cooler than trans “out”.
In the trans pan will be the temp the trans internals will actually see. (This is the location used in all the Chrysler 4 speed transmissions RWD transmissions and all electronic FWD 4 speeds. Since the late 80’s.)
The front servo should show close to pan temp but only see substantial flow in high gear.
The rear servo will only see flow in manual low and reverse and would be the last place I would install a sensor.
As for your dipstick leak, that shouldn’t happen. You either have a bad tube or seal or both. If you can’t fix it then for your application I would tap the bore and install a threaded plug and be done with it. Transmissions today don’t even have dipsticks.
Re: TRANS TEMP T-FITTING ADAPTER [Re: A727Tflite] #2778734
05/27/20 01:29 PM
05/27/20 01:29 PM
T/Anks to all of you for your replies... very helpful and most appreciated!
