Re: Throw out bearing question
[Re: 340swing]
#2777804
05/24/20 08:18 PM
05/24/20 08:18 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Was it an all new setup to the combo? This usually happens when the fork pivot / fork / or bellhousing aren't matched up like they should be. So the clutch works until you drive it or does it happen the first time you push the clutch in? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 340swing]
#2777818
05/24/20 09:02 PM
05/24/20 09:02 PM
fourgearsavoy
Rittman Ohio
I have seen the wrong pivot in the bell throw off the geometry and clips cant hold the TO bearing straight when it contacts the fingers. You would need to get under the car when someone else depresses the clutch pedal so you can see the action. Gus
[Re: 340swing]
#2777996
05/25/20 11:16 AM
05/25/20 11:16 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Pretty much 2 bearings hemi and the standard one.Hemi is huge and would flop around on a 23 spline 4 speed.Rocky
Chrysler Firepower
