70 RR 440 carb advice #2777762
05/24/20 06:34 PM
05/24/20 06:34 PM
Virginia
V
vadartlover Offline OP
V
Virginia
70 440 RR with automatic trans and AC.
So I have an AVS 4640 SA, rebuilt about 10 years ago and never ran.
I also have a thermoquad 2146 just sitting on the shelf.
Since both will be a rebuild (thermoquad more extensive I believe), which is most suitable for a 440?
Re: 70 RR 440 carb advice [Re: vadartlover] #2777781
05/24/20 07:26 PM
05/24/20 07:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What intake ?
Is this a cruiser, a #s-matching car, or what ?
Either carb can be fine, stock '70 intake would need adapter for T-quad.
Re: 70 RR 440 carb advice [Re: topside] #2778145
05/25/20 07:24 PM
05/25/20 07:24 PM
Virginia
V
V
Virginia
Factory cast iron intake. Car is heavily modified, so being correct is not the goal. I think AVS is the answer so far.
Re: 70 RR 440 carb advice [Re: vadartlover] #2778149
05/25/20 07:33 PM
05/25/20 07:33 PM
How big is that carb in CFM? I don't know if that carb # is for a 440 or 383 confused
Re: 70 RR 440 carb advice [Re: Cab_Burge] #2778166
05/25/20 08:17 PM
05/25/20 08:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Application is '69 440 with A/C, which means AT as well.
I don't recall exact CFM, but I don't think it's much more than 650; (383 carbs were less, FWIW.)
I'd lean towards either a new Eddy AVS2 (650-800 CFM) for a modified street engine, better carb than the old tooling & boosters. Under $400.
Some T-quads flow 850 CFM, and the small primaries are nice at part throttle, but you'd need an adapter or a different intake.
Lots of guys prefer Holleys, too. More spendy, + fuel line, kinda more of a race carb, generally speaking.
Tuning any of the Carters seems counter-intuitive to some folks; you have to understand the metering rods, but it's simple & easy once the light comes on.
Re: 70 RR 440 carb advice [Re: topside] #2778182
05/25/20 08:56 PM
05/25/20 08:56 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
4640 is a 750cfm Carb - 440 HP
Nothing wrong with that carb especially if it’s in good shape and you want to install the flat metering rod covers , and then convert to the Edelbrock metering rods/jets
That way you can test and tune the easy way
Watch for the hot idle compensator and vacuum , I like to block them off with my own gasket
Also float level and drop is critical
And the accelerator pump leather drying out
I can’t remember what Edelbrock accelerator pump I ended up using / WAS NOT the Blue one
Flat Metering Rod Covers
Edelbrock
.101 Primary Jets - .065X.052 Metering Rods
.107 Secondary Jets makes for a good start
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 70 RR 440 carb advice [Re: bee1971] #2778306
05/26/20 11:33 AM
05/26/20 11:33 AM
OE AVS's of that era 1968-mid 71 are extremely lean & as Bee said converting to the short Edelbrock performer primary jets/2 step metering rods is mandatory. & besides the jetting the "passages" may also be less than ideal for performance (I cant say as I ain't a carb guy). No knowledge of thermoquads & the tquad guru Demonsizzler in not longer in operation. Just me, you said heavily modified I would go with the new holley spread bore I forget its name (demon or avenger one of those two) & it gets multiple good reviews on here & it would require as said the adapter spacer for a square bore intake. EDIT not sure if it is spreadbore or square
Re: 70 RR 440 carb advice [Re: bee1971] #2778350
05/26/20 01:49 PM
05/26/20 01:49 PM
That jetting combination is way to rich for my motors , especially on the secondary tsk I would find the stock jetting and then maybe make the metering rod .002 to .005 thinner on the top step scope
As far as converting a AVS to use AFB parts that may be the only way you can use for tuning in today world if you don't have a Carter tuning kit for the AVS carbs whiney
I'm lucky that I have two boxes of Carter jets and metering rods from back in the day when you could get parts form Carter at the drag races for free boogie grin
OP, PM me on what your current AVS rod numbers are, I may be able to help you on getting some different ones for tuning your carb., maybe not though with out knowing what you need shruggy
I sold all my AVS carb. cores yrs ago realcrazy
