Change is good
#2775955
05/18/20 09:10 PM
05/18/20 09:10 PM
Posts: 16,153 Mesa, Arizona
dart4forte
Mesa, Arizona
Decided to change to cop wheels.
Old look
New look
Abe Lincoln
Re: Change is good
[Re: poorboy]
#2776086
05/19/20 10:32 AM
05/19/20 10:32 AM
dart4forte
Mesa, Arizona
Walk around to the side in the sun and re-take that after picture. I see a hub cap where I know the front wheel is and a black hole where the I know the rear wheel is. Just because of that, I like the old look better. You can see the slots, even in the shade. Gene Yeah, I took a quickie. Hard to get a good pic that time of the day. I’ll post more pics when I get the other caps sorted out. Have to address the 3” studs in the rear.
Abe Lincoln
Re: Change is good
[Re: dart4forte]
#2776088
05/19/20 10:37 AM
05/19/20 10:37 AM
dart4forte
Mesa, Arizona
The best part is the 15x10s in the back with 275s. The fit is perfect. Split offset fills the wheel well. The front wheels have a different offset than the slots. 15x7 with 255s.
Abe Lincoln
Re: Change is good
[Re: basketcase]
#2776380
05/20/20 09:10 AM
05/20/20 09:10 AM
Posts: 1,385 Az
69hemibeep
Az
1969 Hemi Roadrunner 2nd owner
Re: Change is good
[Re: poorboy]
#2776550
05/20/20 05:56 PM
05/20/20 05:56 PM
dart4forte
Mesa, Arizona
Walk around to the side in the sun and re-take that after picture. I see a hub cap where I know the front wheel is and a black hole where the I know the rear wheel is. Just because of that, I like the old look better. You can see the slots, even in the shade. Gene Here’s some better pics I took this morning
Abe Lincoln
Re: Change is good
[Re: Jjs72D]
#2777592
05/24/20 06:59 AM
05/24/20 06:59 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I like the steelies on dart4forte's better than the slots, but I like the slots better on basketcases truck.
