70 340 block - service replacement ? #2776851
05/21/20 08:41 PM
05/21/20 08:41 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
I picked up a 1970 340 long block assembly. The block was cast in June 70. However, there is no VIN stamping or other assembly info on the block. Was this likely a service replacement bare block at one time? I assume if it would have been built as a long block there would be assembly info stamped on it. Thanks in advance for any info. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 340 block - service replacement ? [Re: 70gtx440dana] #2777215
05/22/20 09:30 PM
05/22/20 09:30 PM
New York
rarefish Offline
rarefish  Offline
New York
I would say yes it is. I had a 340 that looks just like that. No VIN or assembly numbers below the drivers side head stamped. Mine was casted 7/3/70
Re: 70 340 block - service replacement ? [Re: rarefish] #2778349
05/26/20 01:43 PM
05/26/20 01:43 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Must have been a good year for casting extra blocks. Just picked up a 340 block cast 1-5-70. Same thing with nothing stamped in either location.
Re: 70 340 block - service replacement ? [Re: 68jim] #2778357
05/26/20 02:05 PM
05/26/20 02:05 PM
Lansing, MI
Lansing, MI
Thanks for the replies. Seems it is either an over the counter block or possibly a warranty block. I am going to look for evidence of a warranty tag being riveted on the side or front of block area.
Re: 70 340 block - service replacement ? [Re: 70gtx440dana] #2779275
05/28/20 10:04 PM
05/28/20 10:04 PM
Mesa, Az
GETX Offline
GETX  Offline
Mesa, Az
Same thing here as well. I have 1-17-71 cast date with no stampings. shruggy
