Re: Copper spray new steel shim BB head gaskets?
[Re: Cab_Burge]
#2776562
05/20/20 06:40 PM
05/20/20 06:40 PM
Posts: 2,514 PA
moparacer
PA
I put Cometics on dry the first time, then when I reuse them I drill the rivets out, copper coat the thin sides and put them back on.
So its copper coat for me.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2776569
05/20/20 07:16 PM
05/20/20 07:16 PM
Posts: 949 Indiana
68_661charger
Indiana
You know what? The coating does look like dry silver paint. It doesnt rub off. So maybe spray them with paint or copper and put them on wet. Just don't put them on dry?
[Re: 68_661charger]
#2776577
05/20/20 07:52 PM
05/20/20 07:52 PM
Posts: 5,163 CT
GTX MATT
CT
I have used them without putting anything on them. The coating is a high temp coating according to Mr G. I've used them with aluminum heads, and I've even pulled a head off, and put back together with a new gasket without surfacing anything, without a problem. I'm at 11:1 CR. I think mine have about 5000 miles on them.
[Re: 68_661charger]
#2776640
05/21/20 12:05 AM
05/21/20 12:05 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Just so you know, the raised embossing on the steel shim gaskets perform the sealing (combustion and fluids)... not the chemical/spray or whatever you may apply.
I'm a former gasket engineer... your question is common. Applying the chemical, if you choose, must be thin even coating... avoid RTV on the head gaskets.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2776650
05/21/20 05:23 AM
05/21/20 05:23 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I use Hylomar on steel shiim or Cometic
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 68_661charger]
#2776685
05/21/20 10:06 AM
05/21/20 10:06 AM
Posts: 5,163 CT
GTX MATT
CT
From what I gather there is only one company making B/RB steel shim gaskets. I have a set of the Mopar Performance ones with no coating, they are identical to the Mr Gs but no coating on them.
[Re: GTX MATT]
#2776771
05/21/20 02:53 PM
05/21/20 02:53 PM
Posts: 43,227 Bend,OR USA
Cab_Burge
I called Mr. Gasket tech years ago due to seeing a difference in their BB Mopar beaded steel head gaskets from one package to another, I was told that they had stop having them made here in the U.S. and where getting them from China That was some years ago when you could buy them from Fel Pro, Victor and a bunch of other U.S. gasket companies. I'm not sure who makes the Mopar brand head gaskets now I have several different sets in stock, some of the shiny ones and some of the painted ones. I haven't tried using a steel head gasket on a motor with aluminum heads yet
