Quick question answered please... #2776235
05/19/20 07:02 PM
05/19/20 07:02 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
For those of you in the garage right now...
What is the diameter of the register for an 8 bolt crank?
Thats the last bit of info I need before I place an order for a new one to be built..
Re: Quick question answered please... [Re: Jeepmon] #2776254
05/19/20 07:52 PM
05/19/20 07:52 PM
I.D.,O.D., or both?
I think I have a 8 bolt Ohio stroker crank in a motor in the shop I can use to make those measurements from luck
Or do you want a stock street hemi cranks for those measurements?
Re: Quick question answered please... [Re: Jeepmon] #2776255
05/19/20 07:52 PM
05/19/20 07:52 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
walked out to the shop, apox 2.14 also you made me look, it's the same as a 6 bolt crank.
Joe
Without Data, you’re just another guy with an opinion.
Re: Quick question answered please... [Re: sr4440] #2776260
05/19/20 08:08 PM
05/19/20 08:08 PM
Guitar Jones Offline
i think all the modern V8'S are the same. You may run into something different with an old poly or 1st gen hemi. Of course you didn't say what engine you were asking about.
Re: Quick question answered please... [Re: Cab_Burge] #2776262
05/19/20 08:17 PM
05/19/20 08:17 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks Guys..
This is for a BBM wedge motor, it will have a (Chevy) PG trans, TC and Flexplate, so I think I only need the OD of the register...
The previous build had an Ohio crank in it, but we kinda destroyed that when the motor locked up crossing the stripe at 7300 rpm.. so sent it off to the recyclers..
I think I can live with the 2.14" number
So thanks again
Re: Quick question answered please... [Re: Jeepmon] #2776415
05/20/20 11:43 AM
05/20/20 11:43 AM
NC
440Jim Offline
440Jim  Offline
NC
2.156 OD on my Crankshaft.
This pic are the measurements of my PG adapter with JW bellhousing, ATI flexplate.
Re: Quick question answered please... [Re: 440Jim] #2776595
05/20/20 08:38 PM
05/20/20 08:38 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thats perfect.. I literally spend 2 hours searching the internet for a drawing similar to that one..
Thank you so much for your help..
