is there something quick I can do to pop the trunk remotely? #2776177
05/19/20 04:12 PM
05/19/20 04:12 PM
Andrewh Offline OP
Andrewh  Offline OP
I don't need anything fancy and it is just to be able to do it 2 times. Today though.
I thought I could run a wire and pull on the latch, but it doesn't move till I turn the key.
Anyone know what holds that? I don't know if I have enough leverage to turn the lock with a wire.
65 coronet.
Kids need to pick up stuff from school today and they want you to pop your trunk to put stuff in it.
I don't want it bouncing open for pictures or them latching it shut on accident.
Re: is there something quick I can do to pop the trunk remotely? [Re: Andrewh] #2776180
05/19/20 04:16 PM
05/19/20 04:16 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
If you have a spare key, you can just leave it in the lock temporarily. It should stay in the lock while you drive to the school.
Re: is there something quick I can do to pop the trunk remotely? [Re: burdar] #2776182
05/19/20 04:23 PM
05/19/20 04:23 PM
Andrewh Offline OP
Andrewh  Offline OP
it is tricky to open. have to push down and turn the key. would be afraid they might break it.
but I guess that might be the only way.
Re: is there something quick I can do to pop the trunk remotely? [Re: Andrewh] #2776189
05/19/20 04:51 PM
05/19/20 04:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Raise the latch a hair so you don't have to push down. You can always reset it later. shruggy
Re: is there something quick I can do to pop the trunk remotely? [Re: stumpy] #2776271
05/19/20 09:01 PM
05/19/20 09:01 PM
Andrewh Offline OP
Andrewh  Offline OP
wound up just leaving a key in the trunk and telling them how to open it.
Went pretty smoothly.
