Sonic checking a 77 440. #2775586
05/17/20 09:38 PM
05/17/20 09:38 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
So i've been up and down the bores, concentrating on the thrust side of the bores, so far the thinnest spot ive found is .188 on cylinder #5 half way down. Engine is stock bore with about .007 of wear. Any other magic spots to check?
Re: Sonic checking a 77 440. [Re: Uberpube] #2775598
05/17/20 10:24 PM
05/17/20 10:24 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
That sounds almost to good to be true, but for your sake I hope it is, I'd double check the calibration on the meter and recheck but good for you if its that good
Re: Sonic checking a 77 440. [Re: wyoming] #2775602
05/17/20 10:41 PM
05/17/20 10:41 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
There is no magic. In this case, it is what it is... You hunt around till you find the thin spots. Then after you find them you try to rationalize that the thin spots "aren't that bad" and "how many more blocks do I need to test?"
Good Luck
Re: Sonic checking a 77 440. [Re: scatpacktom] #2775606
05/17/20 10:51 PM
05/17/20 10:51 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Haha, yeah i kept checking the calibration slug.. Spent some more time and found an area that is .135 in cylinder 4. Everything on the thrust side looks to be pretty thick.
Re: Sonic checking a 77 440. [Re: Uberpube] #2775607
05/17/20 10:58 PM
05/17/20 10:58 PM
Check both sides, the major and minor thrust sides, if you end up with more than .140 on either side after boring use it, I would and do up
Re: Sonic checking a 77 440. [Re: Uberpube] #2775784
05/18/20 03:44 PM
05/18/20 03:44 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
135 isn’t THAT BAD but it doesn’t HOLD A CANDLE to the earlier 440s or the INFAMOUS industrial 413 block !
I saw one that had just a touch under 250 !
Re: Sonic checking a 77 440. [Re: dOoC] #2775926
05/18/20 08:00 PM
05/18/20 08:00 PM
I've seen some Mopar stock BB.B and 426 Hemi blocks that I have sonic tested have .350 on side an .0120 on the other shock
Most of the early street hemi blocks are decent, some are excellent up But most of those are taken now whiney
I built one new Hemi Mega block that was rough bored to 4.180 and it wasn't thick enough for me to go above 4.250 final bore with a Roots 10:71 on pump swill, we increase the stroke to 4.375 instead of going to 4.310 bore or bigger shruggy
That motor made 927 HP at 7300 RPM on CA pump swill with 7.5 lbs. of boost boogie
The owners chassis wouldn't hook 700 HP, let alone 900+ HP whiney It was a real tire spinner whiney
Re: Sonic checking a 77 440. [Re: Cab_Burge] #2775930
05/18/20 08:17 PM
05/18/20 08:17 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
I think this block will be a good one, thicker than some other blocks ive tried the tester on.
Re: Sonic checking a 77 440. [Re: Uberpube] #2775999
05/18/20 10:58 PM
05/18/20 10:58 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
May not be an issue but you really should be calibrating your tester on the block you are checking, use an area that you can measure with a Mic to compare to the sonic tester is recommended.
Re: Sonic checking a 77 440. [Re: wyoming] #2776153
05/19/20 02:52 PM
05/19/20 02:52 PM
Southern Alberta
Uberpube Offline OP
Uberpube  Offline OP
Southern Alberta
Yeah did that on the mount ear, and also on a mycom compressor cylinder sleave that could be measured with a caliper to see if the cylindrical shape affected the reading. Its reasonably accurate.
Re: Sonic checking a 77 440. [Re: Uberpube] #2776311
05/19/20 11:03 PM
05/19/20 11:03 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Sounds good, hope you have good luck with it, pretty decent block, they can be hard to find
Re: Sonic checking a 77 440. [Re: wyoming] #2776694
05/21/20 10:36 AM
05/21/20 10:36 AM
Nevada
merpar Offline
merpar  Offline
Nevada
On that year block, check and double check your tester. If made in China don't trust it. I had a 400 block tested at the machine shop and it showed the thinnest spot to be just under .250. Had it bored .040 over. Assembled a killer short block. But ran across a killer deal on a KB low deck block. So I sold the short block. It never made it out of the dyno room, several of the cyl's were paper thin. Still feel bad about that deal. Moral of the story, don't trust the sonic checker. If possible find someone with a known good tester and recheck. If it sounds too good to be true. It usually is not true.
Re: Sonic checking a 77 440. [Re: Uberpube] #2955813
08/20/21 09:21 PM
08/20/21 09:21 PM
fl
m880 Offline
m880  Offline
fl
Re: Sonic checking a 77 440. [Re: m880] #2955839
08/20/21 10:34 PM
08/20/21 10:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Offset bore it. But you might lose 2 HP
