Re: Maybe the ultimate first gen dodge rear differential?
[Re: Uberpube]
#2773993
05/12/20 09:09 PM
05/12/20 09:09 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Pretty cool and probably cleaner than my disc swap. I just used brackets from Great Lake Off Road, Cut the spacers from tubing and used 3/4 ton GM front calipers and rotors. You can use Eldorado calipers for a parking brake but I just used a circle track hydraulic brake cut off valve (it's basically just a ball valve) in the rear brake line to use for a parking brake, works very well and it's tons cheaper than the Eldorado calipers, if you can even find them. Now you need a hydroboost.
[Re: Uberpube]
#2799259
07/21/20 09:03 AM
07/21/20 09:03 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: 360view]
#2800764
07/24/20 08:32 PM
07/24/20 08:32 PM
Posts: 5,924 ohio
ruderunner
ohio
I never had the opportunity to put them side by side but, I believe that front calipers from a 97 E250 are the same as the 2nd gen dually disc rear calipers.
The brackets are different for sure but that's the difference between a knuckle and axle tube.
Angry white pureblood male
