What glue to use to fix plastic grill #277368
04/04/09 10:26 PM
04/04/09 10:26 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline OP
On a road near you
On a road near you
9
Have a grill that needs to be repaired, what do you guys use?...thanks...Phill
Re: What glue to use to fix plastic grill [Re: 9 Sec Phill] #277369
04/04/09 10:38 PM
04/04/09 10:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
3M has quite a few products that do work well. Here is a fix that I copied from here a while back.
Start with 100% pure Acetone, buy a gallon.
Pour an ounce or so intp a glass jar (small open mouth jar). Take a scrap grill and using something sharp, scrape off peelings (like pencil shavings size) into the jar of acetone. Put allot of shavings in, the acetone will gradually melt the plastic into a goo. Add enough plastic until the goo reaches toothpaste consistancy. Once you have a good batch melted put the lid on the jar tightly and set it aside. Now, prep your grill as normal, V out cracks on both sides, etc. Use clamps near the joint to alightn the two sides flush and parralell. Smear on some plastic goo, leave it crowned up over the crack like a regular weld looks, let it cure overnight. Sand to flush the next day, fill any pinholes with JB Weld. The crack will practically dissapear at this point, paint as normal
Re: What glue to use to fix plastic grill [Re: NITROUSN] #277370
04/04/09 10:42 PM
04/04/09 10:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Or substitute Acetone for MEK
Re: What glue to use to fix plastic grill [Re: NITROUSN] #277371
04/04/09 10:42 PM
04/04/09 10:42 PM
SK, Canada
E
etek Offline
etek  Offline
E
SK, Canada
That's interesting...or you could just use some fibreglass-filled bondo.
Re: What glue to use to fix plastic grill [Re: etek] #277372
04/04/09 11:01 PM
04/04/09 11:01 PM
None
71rm23 Offline
71rm23  Offline
None
Re: What glue to use to fix plastic grill [Re: etek] #277373
04/04/09 11:03 PM
04/04/09 11:03 PM
N
NITROUSN Offline
NITROUSN  Offline
N
That most likely will not work the best. The above mentioned repairs do work as the bonding agent penetrates the repair pieces and becomes one again.
Re: What glue to use to fix plastic grill [Re: NITROUSN] #277374
04/04/09 11:24 PM
04/04/09 11:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Funny the guy that wrote that all out posted directly below it & got no credit for it... Thanks Scott!!
Re: What glue to use to fix plastic grill [Re: 1_WILD_RT] #277375
04/04/09 11:48 PM
04/04/09 11:48 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Like I said I read and saved it here. If Scott was the one than I agree props to him.
Re: What glue to use to fix plastic grill [Re: NITROUSN] #277376
04/04/09 11:51 PM
04/04/09 11:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It's all good
Re: What glue to use to fix plastic grill [Re: ScottSmith_Harms] #277377
04/05/09 12:30 AM
04/05/09 12:30 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I used the plastic shavings dissolved in acetone to fix some minor damage on a 70 cuda grille, worked perfect! I haven't painted it yet, but the repair is nearly invisible.
Re: What glue to use to fix plastic grill [Re: ScottSmith_Harms] #277378
04/05/09 10:24 AM
04/05/09 10:24 AM
SK, Canada
E
etek Offline
etek  Offline
E
SK, Canada
I'll be trying it ASAP as I'm nearly done my resto and have a crack in the grille to repair! Thanks Scott!!
Re: What glue to use to fix plastic grill [Re: ScottSmith_Harms] #277379
04/05/09 10:53 AM
04/05/09 10:53 AM
US of A
A38s! Offline
A38s!  Offline
US of A
Scott do you have any repaired area photos? I'd consider trying this on a 75 RR grille. The breaks are, thankfully, not on a butted corner, but along the flat stock.
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: What glue to use to fix plastic grill [Re: A38s!] #277380
04/05/09 12:29 PM
04/05/09 12:29 PM
usa
440notchback Offline
usa
Hi all what does MEK stand for i also have a grill that needs repair Thanks
Re: What glue to use to fix plastic grill [Re: 440notchback] #277381
04/05/09 12:34 PM
04/05/09 12:34 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
I believe it's Methyl Ethel Keytone?
Re: What glue to use to fix plastic grill [Re: stubbs300 ] #277382
04/05/09 02:18 PM
04/05/09 02:18 PM
None
71rm23 Offline
71rm23  Offline
None
U R Correct. It stinks to high heaven too. I'd use a mask. I was surprised, I saw it at Lowes even
Re: What glue to use to fix plastic grill [Re: etek] #277383
04/05/09 09:08 PM
04/05/09 09:08 PM
Appleton, Wisconsin
rtmike Offline
rtmike  Offline
Appleton, Wisconsin
OR use JB Weld if your proper educated in redneck like myself!
Its not primer its perma gray.
Re: What glue to use to fix plastic grill [Re: rtmike] #277384
04/05/09 10:13 PM
04/05/09 10:13 PM
Wisconsin
wkroncke17 Offline
wkroncke17  Offline
Wisconsin
I know nobody cares for that Billy Mays guy....but has anyone ever tried "Mighty Putty"?
Seems like it would work??
Re: What glue to use to fix plastic grill [Re: Barnabas_Kriss] #277385
04/06/09 01:45 AM
04/06/09 01:45 AM
Vista, California
ChickMaggot Offline
ChickMaggot  Offline
Vista, California
I fixed a '74 Duster grille (usual cracked mounting legs) using this method, as well. Worked like a charm.
Just make sure you let the repairs dry long enough before sanding. The tip didn't say anything about the ratio of acetone vs shavings and I think my "putty" was a little too wet when I applied it. After letting it dry overnight, I found that it wasn't real solid below the surface when I started sanding.
For good measure, I let the repair dry for another 5-7 days before I attempted sanding again. Once primed, the repair disappeared and it appears rock solid. Heck of a tip.
You can lead a gift horse to water, but you
can't look in his mouth.
Re: What glue to use to fix plastic grill [Re: ChickMaggot] #277386
04/06/09 02:15 AM
04/06/09 02:15 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just make sure you let the repairs dry long enough before sanding. The tip didn't say anything about the ratio of acetone vs shavings and I think my "putty" was a little too wet when I applied it. After letting it dry overnight, I found that it wasn't real solid below the surface when I started sanding. For good measure, I let the repair dry for another 5-7 days before I attempted sanding again. Once primed, the repair disappeared and it appears rock solid. Heck of a tip.
Actually I did address that, but in a subsequent post on the thread linked above
The flash off = The MEK/Acetone will evaporate from the melted plastic. Time varies with the initial mixture, temperature, and other environmental variables.
Bottom line, one day, 3 days, a week, you'll know when it's ready to sand when the plastic returns to a hardened state, if it's not fully cured it can gum up while being sanded.
When you break down ABS this way it does change it's chemical composition somewhat, it will lose some of it's "stiff" properties and stay just a tad to the flexible side (a good thing when fixing cracked/stressed areas) so don't expect it to return to a rock hard state, just close to it.
Also keep in mind that the glueing or welding portion of a plastic repair job is the easy part, the real, skill, time, and effort falls into the sculpting, sanding, priming, painting, etc. Just like body work in miniature. Practice, practice, practice..
Re: What glue to use to fix plastic grill [Re: ScottSmith_Harms] #277387
04/06/09 08:15 AM
04/06/09 08:15 AM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
If you know for sure you have a piece made with ABS you can buy a can of ABS glue at the Depot or Lowes in the plumbing dept for a few $. Not any more than you will pay for a pint of MEK or Acetone and you don't have to find a piece of scrap ABS to melt down.
It all works the same way drain and waste pipes are glued at their joints.
My GTX grill has a small raised "ABS" identifier on the back of it.
Driving modern convenience in classic beauty
