Anyone tried these $400 front disk conversions?
#2773365
05/11/20 12:11 AM
05/11/20 12:11 AM
Posts: 4,848 Memphis
HemiRick
Memphis
$400 disk brake conversion kitJust wondering I've ordered a set and am wondering if I'm the guinea pig? Thanks
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Anyone tried these $400 front disk conversions?
[Re: HemiRick]
#2773369
05/11/20 12:28 AM
05/11/20 12:28 AM
Posts: 2,865 Pattison Texas
CSK
Pattison Texas
I dont find the rotor diameter listed, that said DrDiff is who I recomend
[Re: CSK]
#2773380
05/11/20 02:08 AM
05/11/20 02:08 AM
HemiRick
Memphis
I just installed a Dr Diff kit on a customers car, costs about $250 more if I remember right, for the same basic parts. Neither kit uses the big rotors but with some rotors and caliper brackets this is an easy upgrade. (Big rotors have to have 15" wheels/ these kits will fit most 14") Amazon has a $69 disk brake prop valve. And a parts store master is like $20.
[Re: HemiRick]
#2773381
05/11/20 02:17 AM
05/11/20 02:17 AM
Posts: 10,142 A Red State
SNK-EYZ
A Red State
Copied from the page, Note: Depending on application, additional items may be required to complete installation. 15" wheels required. 15" wheels required
I'd say contact the to be sure, but from that I would think that it has the larger rotors.
[Re: SNK-EYZ]
#2773384
05/11/20 03:33 AM
05/11/20 03:33 AM
HemiRick
Memphis
Ah I was wrong this kit cost less than Dr Diff (small rotors) and appears to have the big rotors. We'll see when I get mine. Says it'll ship early June. My Challenger convert still has drums and one of them is locked up. Rather than work on the drums, I'm gonna install this. If I have to do away w the stock rally wheels so be it.
[Re: moparmarks]
#2773405
05/11/20 08:06 AM
05/11/20 08:06 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Looks like the MBM kit based on the 73-76 A/E factory set up. I've used them and worked fine. yes, definitelly they are offering simply stock parts in a package instead try to hunt the parts separatelly. Like on the disc-o-tech link. The difference is if you search parts separatelly can try to get floating calipers pin kind, which are less trouble maker setup ( noise related ).
[Re: DusterKid]
#2773798
05/12/20 09:53 AM
05/12/20 09:53 AM
Posts: 2,592 None
71rm23
None
I have no experience with the $400 brake kit, I did just however convert my 69 barracuda to front disc using Dodge Dipolot spindles and calipers, etc. After sourcing the correct parts, etc. I would have had probably the same amount of money and a whole lot less time looking for parts if I'd just bought a kit from Doc Diff. I'd go with the proven known kit and save some assembly headaches. My thoughts exactly. "I'd go with the proven known kit and save some assembly headaches. " Which I did from the Dr. and have been happy customer!
[Re: 71rm23]
#2776215
05/19/20 05:53 PM
05/19/20 05:53 PM
HemiRick
Memphis
The brakes just arrived, all assembled, nice. small rotors, 15" wheels NOT required these fit fine inside a 14 factory rally wheel.
[Re: a12rag]
#2776404
05/20/20 11:18 AM
05/20/20 11:18 AM
NachoRT74
Valencia, España
Look nice . . . yes, nicely assembled, but you do have to pull the rotors off in order to mount the spindles . . . True... the ball joint bolts goes from front to rear!!!
[Re: NachoRT74]
#2776439
05/20/20 12:20 PM
05/20/20 12:20 PM
HemiRick
Memphis
Not only that but I bet the bearings aren't greased either.....Yes I know I have to take it apart some to install on car.
