Re: where to buy rotors for 72 Satellite cheep as possiable
[Re: GLR]
#277316
04/04/09 09:41 PM
04/04/09 09:41 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Try the NAPA, Parts Plus, Carquest, ect brands. Bought a set of Parts Plus for 55.00 ea a couple years back.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: GLR]
#277320
04/04/09 10:38 PM
04/04/09 10:38 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Hello, I have a customers car a 1972 Plymout satellite (Road Runner clone) for a 19 year old kid and I am trying to keep his cost down on his car but the brake rotors that Year one has to replace his are $269.00 each!...Does anyone know where to buy them cheeper? I have checked with Autozone and Advance and they can't get them. Is there a way to use a rotor for another yer/type of Mopar?
Try www.rockauto.com
They run about $75 per side..
[Re: 1_WILD_RT]
#277329
08/23/09 03:39 PM
08/23/09 03:39 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
My spindle sleeve kit includes 2 spacers and 2 seals so you can run '73 and newer A,B,E,F,M,J body 10.95" or 11.75" rotors on '70-'72 B or E body disc knuckles.
Use '73 and newer inner wheel bearings.
Of course, you must also change the caliper brackets, if you want to run the larger 11.75" rotors.
[Re: GLR]
#277333
08/23/09 04:57 PM
08/23/09 04:57 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
Well, I got the 11 3/4 " rotors off the 1975 Monoco...so I will use them... Can I use the caliper brackets off the Monoco also or do I need yours?
Are those rotors the same as the Cordoba rotors ???
The other thread NO COMBINATION of parts will allow you to use C BODY PARTS ....
