Re: Are reringed engines harder to turn over?
[Re: stumpy]
#277303
04/06/09 07:32 PM
04/06/09 07:32 PM
BRawls
super gas
super gas
It takes about 50-55 ft lbs of torque to turn the engine over. The cylinders probably have next to no oil on them so that could be part of the reason but still I didnt think itd be that hard.
That is going to be about right for a fresh engine.
Also, if you used moly on the bearing surfaces instead of oil, it will make a BIG difference in the break-away number.
