70 Air Grabber Switch Mounting #2771214
05/04/20 08:24 PM
05/04/20 08:24 PM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
Trying to put a AG switch into my original non AG car.(Was a A/C car) I have the hole location correct but can’t figure out how the switch mounts. Am I missing a spacer? There is a heck of a gap.
Thanks!
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: 70 Air Grabber Switch Mounting [Re: A70Runner] #2771218
05/04/20 08:32 PM
05/04/20 08:32 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
The switch itself gets mounted to the metal dash frame. The switch bezel gets mounted to the plastic dash cover.
Re: 70 Air Grabber Switch Mounting [Re: 70HemiGTX] #2771238
05/04/20 09:22 PM
05/04/20 09:22 PM
Mooresville, NC
Mooresville, NC
The problem I have is that the plastic and the metal dash frame won’t fill up that much room. Lol. The switch is up against the bezel in my hand.
Re: 70 Air Grabber Switch Mounting [Re: A70Runner] #2771318
05/05/20 08:54 AM
05/05/20 08:54 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
As suggested......mount switch to dash frame from back side. Switch bezel mounts to plastic trim from front side. There is an air gap between dash frame and dash plastic trim.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 70 Air Grabber Switch Mounting [Re: 70gtx440dana] #2772972
05/09/20 07:22 PM
05/09/20 07:22 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
That gap is there. Period. Not much you can do about it. It was pretty crude.
Re: 70 Air Grabber Switch Mounting [Re: 70HemiGTX] #2772978
05/09/20 07:45 PM
05/09/20 07:45 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
It seems to be a crude fit from the factory. This is the best shot I have.
Re: 70 Air Grabber Switch Mounting [Re: 70gtx440dana] #2772994
05/09/20 09:19 PM
05/09/20 09:19 PM
Mooresville, NC
Mooresville, NC
This was the answer I was looking for. Thanks!!
Re: 70 Air Grabber Switch Mounting [Re: 469runner] #2773016
05/09/20 10:39 PM
05/09/20 10:39 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
You hit the nail on the head. The alignment wasn't the greatest either.
