70 RR Hood Turn Signals #2772918
05/09/20 04:07 PM
05/09/20 04:07 PM
Mooresville, NC
A70Runner Offline OP
Mooresville, NC
Ok I have a new wiring harness to the hood. Problem I have is the PO butcher the bulbs that go in the lenses. I found repo lenses that have bulb holders but don’t want to spend that much because my lenses are nice. Does anyone rep just the bulb holder or has anyone done a LED conversion? Thanks!
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: 70 RR Hood Turn Signals [Re: A70Runner] #2772969
05/09/20 07:15 PM
05/09/20 07:15 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I had one of those that the barrel nut was rusted fast. I very carefully pushed the lens out from the rear and cleaned everything up. Then I found a set of fender mounted turnsignal indicators that were shot. I took them apart and the barrel nuts are an exact match. I put the part in the bezel and mixed a little epoxy to hold it in place. Quick fix and it lasted.
