Re: Are reringed engines harder to turn over? [Re: stumpy] #277303
04/06/09 07:32 PM
04/06/09 07:32 PM
BRawls Offline
super gas
BRawls  Offline
super gas
It takes about 50-55 ft lbs of torque to turn the engine over. The cylinders probably have next to no oil on them so that could be part of the reason but still I didnt think itd be that hard.
That is going to be about right for a fresh engine.
Also, if you used moly on the bearing surfaces instead of oil, it will make a BIG difference in the break-away number.
Re: Are reringed engines harder to turn over? [Re: BRawls] #277304
04/06/09 08:00 PM
04/06/09 08:00 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Whatever I used was stuff they gave me with some new crank brearings for another engine I done. I unhooked the valvetrain and its showing around 40 ft lbs. I guess Ill run it... the cylinders all look fine. I did notice some of them have a grey powdery stuff on them now.. is that from the rings breaking in?
Re: Are reringed engines harder to turn over? [Re: derekeh] #277305
04/07/09 02:12 AM
04/07/09 02:12 AM
El Cerrito, by San Francisco
last426 Offline
last426  Offline
Gesh, start it up and forget about it. I haven't done an engine in a long time but I was so anxious to see if it worked I couldn't stand it. Check out my hemi here. Vroom, vroom Kim
Re: Are reringed engines harder to turn over? [Re: derekeh] #277306
04/07/09 08:42 AM
04/07/09 08:42 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Grey powdery stuff? I hope the pistons weren't installed dry. The pistons should have been oiled along with the cylinder walls prior to assembly. If not, it would be a good idea to take those pistons back out and dip them in oil. New rings and freshly honed cylinders will create drag and make the engine tighter, even with oiled walls. DO NOT start that engine with dry pistons.
Re: Are reringed engines harder to turn over? [Re: GODSCOUNTRY340] #277307
04/07/09 04:55 PM
04/07/09 04:55 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
I did oil them.
Re: Are reringed engines harder to turn over? [Re: derekeh] #277308
04/07/09 05:17 PM
04/07/09 05:17 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
do you know ring tension for each cylinder?
