Re: Engine diesels on shut off?
[Re: GODSCOUNTRY340]
#2772791
05/09/20 10:56 AM
05/09/20 10:56 AM
Posts: 3,514 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Usually the idle is too high, causing dieseling. I would agree. Also any chance you got a bad tank of gas. What is your compression ratio and what fuel do you run? As carbon builds up over the years octane requirement can go up.
#2772803
05/09/20 11:11 AM
05/09/20 11:11 AM
Posts: 128 Troy,MI
Siba
Troy,MI
Usually the idle is too high, causing dieseling. Agree! I had the same problem but my engine needed the higher idle. My fix was back down the idle on the carb (to get it back on the idle circuit) and then I increased the initial timing. Problem solved.
[Re: 6T9RR]
#2772876
05/09/20 01:37 PM
05/09/20 01:37 PM
Posts: 44 Youngstown
Vincenzo
Youngstown
What do you mean, the timing is “right” hopefully you are not timing to 1969 specs. This fuel needs a little more time to complete its burn.
Woodruff Carburetor Specialties 330-799-9479
[Re: 6T9RR]
#2772964
05/09/20 06:53 PM
05/09/20 06:53 PM
Vincenzo
Youngstown
Give that thing some initial timing. It will probably respond well to 15-20 Btdc. Remember what ever you put into the bottom also goes to the top. You don’t want to be 40 total.
[Re: Stanton]
#2772981
05/09/20 07:50 PM
05/09/20 07:50 PM
Posts: 3,077 Michigan
A727Tflite
I always wondered why my car would diesel but every race car I ever saw would shut off clean. I wonder too.
[Re: 6T9RR]
#2773017
05/09/20 10:41 PM
05/09/20 10:41 PM
Guitar Jones
The combustion chamber temperature is too high and that can cause carbon in the cylinder to glow and continue to ignite fuel. This used to be quite a problem in the late 70's and early 80's when manufacturers where trying all kinds of things to get their engines to meet emmisions. Crappy fuel that ignites easily, too high of an idle speed, a carb problem, too much or too little ignition timing can all contribute to the condition as well as an escalated engine coolant temperature.
[Re: Guitar Jones]
#2773079
05/10/20 08:21 AM
05/10/20 08:21 AM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
The combustion chamber temperature is too high and that can cause carbon in the cylinder to glow and continue to ignite fuel. This used to be quite a problem in the late 70's and early 80's when manufacturers where trying all kinds of things to get their engines to meet emmisions. Crappy fuel that ignites easily, too high of an idle speed, a carb problem, too much or too little ignition timing can all contribute to the condition as well as an escalated engine coolant temperature. Exactly why manufacturers used idle solenoids. For the younger guys (and gals), you would set the idle speed to spec with the solenoid. Then when you shut the engine off, the solenoid allowed the throttle blades to close. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
