B Body Wiper Linkage Question #2772585
05/08/20 07:19 PM
05/08/20 07:19 PM
Virginia
V
vadartlover Offline OP
V
Virginia
I searched for this number for the windshield wiper linkage: 2857 922 58622. It showed as being for either a two speed or a three speed wiper motor. Can anyone tell me if this is correct?
Re: B Body Wiper Linkage Question [Re: vadartlover] #2772647
05/08/20 10:44 PM
05/08/20 10:44 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What exactly are you looking for. The two pivots and the linkage arms are the same 2 speed vs 3 speed. The crank arm off the motor and the plastic cams are different between the two motors. Also what year car?
Re: B Body Wiper Linkage Question [Re: NITROUSN] #2772716
05/09/20 07:31 AM
05/09/20 07:31 AM
Virginia
V
V
Virginia
This is for a 70. I was told but haven't verified that the wiper motor is a three speed and I thought I read where the linkage assembly was different. I have two sets of the linkage and they look the same and the numbers are the same. I have the dash disassembled right now and want to correct any issues before reassembling.
Re: B Body Wiper Linkage Question [Re: vadartlover] #2772720
05/09/20 07:41 AM
05/09/20 07:41 AM
VA
dragon slayer Offline
VA
As stated the linkage was the same. You just need the 3 speed crank arm 2822273 and the 3 speed bushing.
Re: B Body Wiper Linkage Question [Re: vadartlover] #2772771
05/09/20 10:07 AM
05/09/20 10:07 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The 68-70 B body wiper linkage is the same for 2 or 3 speed motors, if you have 2 spd and converting to 3 spd, you'll need the 3 spd motor with correct crank arm/bushing, 3 spd dash switch, the wiring harness has provisions/hook up for 2 or 3spd switch provided from the factory...
Mike
Re: B Body Wiper Linkage Question [Re: vadartlover] #2772773
05/09/20 10:12 AM
05/09/20 10:12 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
This is a 3 spd wiper motor
Re: B Body Wiper Linkage Question [Re: DAYCLONA] #2772774
05/09/20 10:14 AM
05/09/20 10:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
2 spd...
Re: B Body Wiper Linkage Question [Re: DAYCLONA] #2772778
05/09/20 10:22 AM
05/09/20 10:22 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
2 and 3 spd B body switches look the same "face/switch/rocker wise", but the 3 spd will have an external resistor on the back side, as seen below
Mike
switchcccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccccc.JPGswitch3dsp.JPG
Re: B Body Wiper Linkage Question [Re: DAYCLONA] #2772966
05/09/20 07:00 PM
05/09/20 07:00 PM
Virginia
V
V
Virginia
I definitely have the the 3 speed motor, checked it today.
So if I am reading the replies correctly, I just need the 3 speed switch and may have to play around with the wires.
Do this sound correct?
Re: B Body Wiper Linkage Question [Re: vadartlover] #2773152
05/10/20 11:58 AM
05/10/20 11:58 AM
VA
VA
Dos the motor have the crank arm? Also you need to change bushing in the linkage drive arm to 3 speed, if the original was on a 2 speed.
Re: B Body Wiper Linkage Question [Re: vadartlover] #2773179
05/10/20 12:55 PM
05/10/20 12:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The under dash harness/switch connection is already there to accept the 3 spd switch, plug and play, but you need to make sure your 3 spd wiper motor is for a B body application, the crank arm and firewall harness plug ends on the motor are specific to your B body 2 gen (68-70) Dodge/Plymouth
Here's what a 70 B body 3 spd wiper conversion consist of:
Your wiper crank arm should be pn# 2822273 if OEM, repro arms and bushings are available repro if needed
Re: B Body Wiper Linkage Question [Re: DAYCLONA] #2773199
05/10/20 01:57 PM
05/10/20 01:57 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
There is a small brown jumper wire on the switch end of the wiring harness. It can be missing on cars originally equipped with a 2sp
NS1AAR
