Re: guy insists his 66 Coronet is pos ground. [Re: 71TA] #2772087
05/07/20 12:26 PM
05/07/20 12:26 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Starter will work either way, as will any motor in the car. BTDT when I converted my 51 to 12V negative ground from 6v positive ground. No radio in the car so that wasn't an issue. I did swap out the gauges to an aftermarket setup so I dunno about them.
Re: guy insists his 66 Coronet is pos ground. [Re: Sniper] #2772099
05/07/20 01:02 PM
05/07/20 01:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Chrysler changed over to a negative ground in 1956 except for a few late model Imperials
wave
Re: guy insists his 66 Coronet is pos ground. [Re: Sniper] #2772130
05/07/20 03:32 PM
05/07/20 03:32 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I do not see how any 12 volt DC motor will spin the same direction when reversing polarity. This is exactly how power widows reverse to roll up and down . They may still work but when you push the button for up, they will go down and Vice-versa. And power door locks work this way too, power antenna will also work but in reverse.
I have used a Mopar starter as a electrical motor on a powered cement wheelbarrel. No bendix spring, direct drive, sprocket welded on the shaft. When 12 V Neg grounded it moved forward. When switched to Pos ground it backed up.
My observations over the years:
Radios may burn out.
Light bulbs do not care.
Ign Coils will spark backwards and burn out sparkplugs tips.
Gauges may reflect backwards.
Electric Puller fans will become Pushers.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: guy insists his 66 Coronet is pos ground. [Re: Dave_J] #2772178
05/07/20 05:39 PM
05/07/20 05:39 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You are welcome to come over and tell the starter on my 51 it's not behaving properly.
Series wound motors do not care about polarity. They turn the same direction regardless.
Re: guy insists his 66 Coronet is pos ground. [Re: Sniper] #2772200
05/07/20 07:04 PM
05/07/20 07:04 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
Permanent-magnet DC motors change direction with the polarity of the applied current. Wound-field motors do not, because the armature and field currents both reverse but not relative to each other.
Re: guy insists his 66 Coronet is pos ground. [Re: BSharp] #2772214
05/07/20 07:47 PM
05/07/20 07:47 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
This. ^^^
Kevin
Re: guy insists his 66 Coronet is pos ground. [Re: Twostick] #2772220
05/07/20 07:54 PM
05/07/20 07:54 PM
Virginia
BSharp Offline
BSharp  Offline
Virginia
I just looked it up. laugh
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2772399
05/08/20 10:42 AM
05/08/20 10:42 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Wait....does his car also have a reverse rotation 383 Hemi 12 pack with a 727 Turbo and a posi locker detroit sure grip rear end?
I think I know the guy (he used to call the Mopar Tech Line).
Rich H.
Esse Quam Videri
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2772419
05/08/20 11:24 AM
05/08/20 11:24 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Originally Posted by HemiRick
We've got a new member of our local mopar club and he insists his 66 Coronet is pos ground. the pos cable is going to the block and the neg to the starter he says...Is he badly mistaken?...How is this possible?
Thanks for your thoughts
Rick
You guys should make it a requirement to join your club that members have some basic automotive knowledge. He’s going to be a reflection of your club when he’s out representing you. Somebody needs to school the young man.
Abe Lincoln
Re: guy insists his 66 Coronet is pos ground. [Re: dart4forte] #2772422
05/08/20 11:36 AM
05/08/20 11:36 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Rick
see Zippy's response, that is what I think when I hear car club lol
68 Barracuda Formula S 340
Re: guy insists his 66 Coronet is pos ground. [Re: dart4forte] #2772564
05/08/20 06:12 PM
05/08/20 06:12 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Rick
There are those in this hobby that don't turn their own wrenches. He might be one of them.
Re: guy insists his 66 Coronet is pos ground. [Re: MarkZ] #2772568
05/08/20 06:19 PM
05/08/20 06:19 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
Ask your new fellow club member, if he hangs out with JJ Da Boss? work
Plymouth Makes It!
Re: guy insists his 66 Coronet is pos ground. [Re: RoadRunnerLuva] #2772582
05/08/20 07:08 PM
05/08/20 07:08 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
I've met JJ and he's not near as redneck IRL as portrayed on TV, actually seems to me to be a smart guy.
Found out the guy w the Coronet is in Southern Missouri about a couple hours away from Memphis....If he was in town I was going to go look.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: guy insists his 66 Coronet is pos ground. [Re: dart4forte] #2772588
05/08/20 07:24 PM
05/08/20 07:24 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Nobody mentioned the age of this person, just that he was a new member.
Age is no reflection of intelligence either. I have met smart and stupid of all ages. It is especially sad when it is an older person though.
Backing up slightly, you can't mandate intellect for new members. Part of the reason that some join a club is to learn. I was in a car club after I bought my Duster. I was 25 and didn't know much. I'm still learning. Aren't we all ?
Re: guy insists his 66 Coronet is pos ground. [Re: Jjs72D] #2772650
05/08/20 11:02 PM
05/08/20 11:02 PM
Castlegar, BC, Canada
That AMC Guy Offline
As Bugs Bunny used to say: "What a MAROON!"
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: guy insists his 66 Coronet is pos ground. [Re: HemiRick] #2772675
05/09/20 12:42 AM
05/09/20 12:42 AM
Land 'O Lakes
Land 'O Lakes
Well to me, I guess he is smart enough to snag a TV show, that seems to be more popular than the OG Street Outlaws show ?
His son though "doughboy"...he is, or at least plays the part really good, of a stone cold redneck! laugh2
Plymouth Makes It!
Re: guy insists his 66 Coronet is pos ground. [Re: RoadRunnerLuva] #2772775
05/09/20 10:18 AM
05/09/20 10:18 AM
moparx Online content
moparx  Online Content
the older i get, i find out i'm dumber than i thought i was. biggrin
beer
