Attention EFI Users
#2770898
05/03/20 07:50 PM
05/03/20 07:50 PM
Posts: 16,135 Mesa, Arizona
dart4forte
Mesa, Arizona
I’m getting ready to pop the fuse in ordering an EFI setup. I’ve watched numerous Utube vids on Fitec, Holley Sniper and the Edelbrock system. My biggest concern is customer service. Any comments concerning the customer service for each?
I have a 74 D100 with a 318 auto which is my mule for setting up a system.
Abe Lincoln
Re: Attention EFI Users
[Re: GoodysGotaCuda]
#2770975
05/04/20 12:27 AM
05/04/20 12:27 AM
Posts: 30,998 Oregon
AndyF
I've installed a FiTech in my in-law's Truck. It runs quite well but the interface is pretty clunky.
When it's time to put one in my Warlock, I'll give Holley a try. A huge amount of the installation troubles are user induced, primarily around RFI/noise and adjustments that need to be made by the user. That is true. I visit the Holley Sniper forum on a regular basis and many if not most of the problems that people have are because they didn't read the instructions. People bolt them on and start playing with them and then it doesn't run. Installing EFI isn't the same as bolting on a carb. It is more like getting a new laptop to work. Things need to be connected properly and the files have to be loaded into the right spot and the cables have to be routed correctly. It isn't difficult to do, it just has to be done correctly.
[Re: AndyF]
#2770996
05/04/20 07:24 AM
05/04/20 07:24 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
If I were to buy one of the Throttle Body units on the Market today It would no doubt be the Holley.
68 Barracuda Formula S 340
[Re: AndyF]
#2771039
05/04/20 10:34 AM
05/04/20 10:34 AM
dart4forte
Mesa, Arizona
A little off the intended subject I was looking at the intank fuel pump and it seems that the inline pump would be the way to go. The only complaint I’ve heard on the inline is the noise. I have a Tanks Inc. 16 gallon located behind the rear end and can always switch later if the inline doesn’t work.
Abe Lincoln
[Re: dart4forte]
#2771045
05/04/20 10:47 AM
05/04/20 10:47 AM
Posts: 3,318 Southern Maryland
klunick
Southern Maryland
Installing a Holley Sniper right now. All seems to be pretty good but I was a tad bit surprised to find out the CPU learning curve is about 500 miles. On the other hand, maybe not.
67 Barracuda FB
69 Superbee
"Southern Maryland: If you want a good looking woman, you had better bring her with you"
[Re: larrymopar360]
#2771451
05/05/20 02:17 PM
05/05/20 02:17 PM
dart4forte
Mesa, Arizona
What about mounting the Sniper to a Performer. I also saw a vid where a duel plane screws with the MAP sensor. Have to add a spacer or cut down the intakes divider. Is this true?
Abe Lincoln
[Re: Mopar_Rich]
#2771628
05/05/20 10:08 PM
05/05/20 10:08 PM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
I sell and support Holley EFI. I DO answer the phone too! do you still support FAST also, the biggest piece of crap ever produced, that I spend thousands ,because you also supported, all I ever heard from them was your out of warranty,as my quad driver failed twice,and flooded the motor .... met with u at Carlilse years ago and you had no answers,and I was not the the only one, every one was having problems, you just blew it off.....PATHETIC....
[Re: 70Challengerse]
#2771687
05/06/20 03:08 AM
05/06/20 03:08 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
I sell and support Holley EFI. I DO answer the phone too! do you still support FAST also, the biggest piece of crap ever produced, that I spend thousands ,because you also supported, all I ever heard from them was your out of warranty,as my quad driver failed twice,and flooded the motor .... met with u at Carlilse years ago and you had no answers,and I was not the the only one, every one was having problems, you just blew it off.....PATHETIC.... FAST was one of the leaders 10-15 years ago and their higher end XFI products still work, and yes I am one of the ONLY people that still answer the phone and I will support a FAST user if they have one of the higher end products. FAST made a mistake with the lower end systems. There's nothing I can do for an EZ user where I cannot get into the software. 99.9% of my sales are other products, such as Holley, but I still want to help if I can. So I actually DO answer the phone and I'm proud to be known for that.
