Alternator Not Charging 1971 Roadrunner #2770445
05/02/20 01:53 PM
05/02/20 01:53 PM
Oak Forest, Texas
markshemiworld Offline OP
Oak Forest, Texas
Ok so I’m looking for some wisdom/advice on how you guys would proceed.
Car is a 1971 Plymouth roadrunner with a 440 six pack. I purchased a new round back alternator to replace the one that was in the car. The previous one was a low output (48 I think) and I went with a 90 amp power master 2 field round back. After connecting it, there is no charge coming from it. The wiring harness is new (less than 10 years old) and I have replaced the voltage regulator and made sure it had a clean good ground on the firewall. I have checked that both field wires have a good connection on the back of the alternator and the black wire is tight and sandwiched between two nuts on the output stud. I have checked the full wire going into the ammeter and it is clean and the ammeter looks good and is reading a slight discharge when the car is running (drops lower when I turn the lights on). What else should I be looking for?
Thanks ahead of time!
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770446
05/02/20 01:57 PM
05/02/20 01:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you getting 12v to the stud on the alt?
Re: Alternator Not Charging 1971 Roadrunner [Re: stumpy] #2770453
05/02/20 02:06 PM
05/02/20 02:06 PM
Oak Forest, Texas
Oak Forest, Texas
How would I go about checking that?
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770457
05/02/20 02:31 PM
05/02/20 02:31 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
First you need a multi meter (even an el-cheapo from HF ) put it on the DC volt scale and check voltage at the large black wire on the alternator. Did your older alternator work at all? Did it keep the battery charged?
Gus beer
64 Plymouth Savoy
Dana 60
Re: Alternator Not Charging 1971 Roadrunner [Re: fourgearsavoy] #2770464
05/02/20 02:53 PM
05/02/20 02:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Or use a test light.
Re: Alternator Not Charging 1971 Roadrunner [Re: stumpy] #2770470
05/02/20 03:22 PM
05/02/20 03:22 PM
Oak Forest, Texas
Oak Forest, Texas
My last alternator seemed to work just fine, although it suffered from the typical mopar problems of low output at idle and such but car has not been driven much in the last several months so I’m not sure if it was working or not. Ok so with the power off Check and see if there is 12 volts at the alternator output post. What will this tell me?
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770475
05/02/20 03:44 PM
05/02/20 03:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you have the original green and blue wires to the fields, check that the blue wire is providing 12V when the ign. sw. is ON. If good, remove the green wire and temporarily ground the green terminal...this should sent the alternator into max charge.
Re: Alternator Not Charging 1971 Roadrunner [Re: John_Kunkel] #2770477
05/02/20 03:53 PM
05/02/20 03:53 PM
Oak Forest, Texas
Oak Forest, Texas
Ok so this will tell me if the alternator is good?
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770481
05/02/20 04:03 PM
05/02/20 04:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The 12v at the stud tells you the alternator can be excited. Necessary for it to charge. The grounding of the green terminal will tell you if the alternator is good. Just don't allow it to over charge for very long.
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770483
05/02/20 04:06 PM
05/02/20 04:06 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You alternator has three wires hooked up to it.
the fat black one you mentioned, that is the output, it goes to eh battery via the ammeter.
A blue wire, this one comes from the ignition switch and provides a switched 12V to the alternator so it can operate.
A green wore that comes from teh regulator, this is what controls the alternator output.
The black wire should have 12V on it all the time
The blue wire should have power on it when the key is in run.
If neither of those is true you have a wiring issue.
The green wire will have a variable voltage on it is it's controlling and the key is on. Grounded turns the alternator on to max, 12v turns it all the way off, somewhere in between it's putting out something more than nothing, but less than max (sorry no output chart that I know of).
You can temporarily remove the green wire from the alternator connection and replace it with a jumper wire, if you ground that jumper with the engine running and the other wires all hooked up it should make the alternator charge. If it doesn't the alternator is bad. If it does you have a wiring issue. Just connect the jumper long enough to verify charging is happening. You meter can tell you that or you can take a quick look at the ammeter.
Tell us what you find.
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770497
05/02/20 04:51 PM
05/02/20 04:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It will move the amp gauge it its max charge unless your gauge is burnt out
wave
Re: Alternator Not Charging 1971 Roadrunner [Re: MR_P_BODY] #2770502
05/02/20 05:13 PM
05/02/20 05:13 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
1971 should have a "square back" alt with 2 field brushes, and with an electronic regulator. using a round back replacement may be your problem!
Re: Alternator Not Charging 1971 Roadrunner [Re: Sniper] #2770508
05/02/20 05:59 PM
05/02/20 05:59 PM
Oak Forest, Texas
Oak Forest, Texas
Ok so there is no power at the alternator post with the car off and key off. This should mean that my ammeter has failed and I need to bypass that. Am I correct?
Re: Alternator Not Charging 1971 Roadrunner [Re: volaredon] #2770509
05/02/20 06:08 PM
05/02/20 06:08 PM
Oak Forest, Texas
Oak Forest, Texas
I’ve been running a dual field (2 brushes) alternator with an electronic regulator for 50,000 Miles now without a problem. I’m wondering if my ammeter gave way at this point and if so, what’s the best solution?
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770513
05/02/20 06:17 PM
05/02/20 06:17 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Might be the ammeter, might be the wiring.
What's teh vvoltage ont he stud with the engine running? That will tell the tale.
Re: Alternator Not Charging 1971 Roadrunner [Re: Sniper] #2770514
05/02/20 06:24 PM
05/02/20 06:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If the starter turns over then the ampmeter is ok all the ignition power goes through it.
Re: Alternator Not Charging 1971 Roadrunner [Re: stumpy] #2770520
05/02/20 07:05 PM
05/02/20 07:05 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
id be looking at fusible links..... going thru something similar on one of my trucks.
Re: Alternator Not Charging 1971 Roadrunner [Re: volaredon] #2770575
05/02/20 10:15 PM
05/02/20 10:15 PM
Oak Forest, Texas
Oak Forest, Texas
Ok everybody here is what I found-
I traced back the issues as y’all suggested starting with the post on the alternator. I found that I had no power at the alternator stud but I had full power all the way through the ammeter, but somewhere between the alternator stud and the back of the ammeter I had a short in the wire. I replaced this line with new 12 gauge wire and that solved my issue! As always I appreciate the advice and wisdom of you guys!
Re: Alternator Not Charging 1971 Roadrunner [Re: markshemiworld] #2770576
05/02/20 10:17 PM
05/02/20 10:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Have you inspected both brushes to make sure they are spring loaded properly and engaging? one or both may be hung up?....
Re: Alternator Not Charging 1971 Roadrunner [Re: DAYCLONA] #2770579
05/02/20 10:25 PM
05/02/20 10:25 PM
Oak Forest, Texas
Oak Forest, Texas
Thanks for the suggestion! I will be sure I give that a check next time as well! For now the alternator is charging as it should
