Electrical Out #2770213
05/01/20 05:15 PM
05/01/20 05:15 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Hey folks,
1970 340-6 Challenger with electronic ignition kit.I turned the key, heard a loud "click" from the engine bay on the firewall in front of the glove box (ECM? Voltage regulator? There's a ceramic resistor over there too), then all power was gone, no ignition, dome light and headlights were out. I checked the ceramic resistor and it "looked" okay, no burns or flash marks.
I replaced the starter relay. Had lights and power. Turned the key and same thing. Loud "click" in the engine bay but no maybe lower down by the starter.
Any ideas as to where to start testing?
Thanks!
Re: Electrical Out [Re: T/A CARe] #2770221
05/01/20 05:39 PM
05/01/20 05:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Is the click coming from the starter relay or the starter? If its the starter, hit it w a hammer and try again. The Bendix maybe sticking.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Electrical Out [Re: HemiRick] #2770223
05/01/20 05:43 PM
05/01/20 05:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If you can't get a clear shot on the starter due to stuff in the way, put a 2x4 on the starter then smack the end of the 2x4. Easier to do that then hit something you didnit want to hit.
Re: Electrical Out [Re: HemiRick] #2770231
05/01/20 06:30 PM
05/01/20 06:30 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Thanks! I'm going to need to get a someone to turn the key so I can go out and listen...
Re: Electrical Out [Re: Sniper] #2770232
05/01/20 06:32 PM
05/01/20 06:32 PM
Colorado Springs
T/A CARe Offline OP
T/A CARe  Offline OP
Colorado Springs
Thanks! Great tip!
Re: Electrical Out [Re: T/A CARe] #2770271
05/01/20 09:59 PM
05/01/20 09:59 PM
N
NITROUSN Offline
NITROUSN  Offline
N
If your losing all power it sounds like dirty battery cable connections.
Re: Electrical Out [Re: NITROUSN] #2770278
05/01/20 10:15 PM
05/01/20 10:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check both ends of your battery cables. Make sure the ground is good.
Re: Electrical Out [Re: stumpy] #2770282
05/01/20 10:20 PM
05/01/20 10:20 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Didn't anyone else wonder what voltage the battery has? Or the condition of the battery cables and connections? Gene
Re: Electrical Out [Re: poorboy] #2770295
05/01/20 10:47 PM
05/01/20 10:47 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
iagree Do some basic electrical troubleshooting before playing Ford mechanic with a hammer. grin
Re: Electrical Out [Re: stumpy] #2770358
05/02/20 09:22 AM
05/02/20 09:22 AM
ILLINOIS
V
volaredon Online content
volaredon  Online Content
V
ILLINOIS
had that on my 78 Fury last summer. the battery to starter cable seemed OK, but it corroded and lost contact right at/ within the lead terminal at the battery..... replaced the battery cable and no more issues.
but it "looked" fine.
