oem 1.88 valve question #2770082
05/01/20 10:29 AM
05/01/20 10:29 AM
Super Spudsville
Mr PotatoHead Offline OP
Half Baked
Half Baked
Super Spudsville
Im putting a set of 1.88 in place of a std. 318 intake valve and just dug out my 1.88 valves.
The length is correct, a test lap shows great pattern but then I noticed its got a 4 groove lock.
I tossed the boxes long ago.
Did they make a 4 groove 1.88 intake or do I have some sort of 1.88 ex. valve? It does not have a wider margin then the 1.78 oem?
So whats up? And if this is in reality an ex valve, could I still use it as a HD intake?
Any input would be great as im not well versed in this area.
Oem 1.78 is 117 grams, this 1.88 is 123 grams.
Thanks.
STOP POTATO HATE!
Re: oem 1.88 valve question [Re: Mr PotatoHead] #2770089
05/01/20 10:43 AM
05/01/20 10:43 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
They come both ways.
Most are 4 groove.
Just get the correct locks and you’re good to go.
If the seats haven’t been cut for that size valve, there isn’t going to be really any benefit to using them, and it will likely create a spring installed height and/or a valve tip height problem.
Re: oem 1.88 valve question [Re: fast68plymouth] #2770092
05/01/20 10:46 AM
05/01/20 10:46 AM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Thank you sir, as always!
STOP POTATO HATE!
Re: oem 1.88 valve question [Re: Mr PotatoHead] #2770209
05/01/20 05:04 PM
05/01/20 05:04 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Agree, both ways.
The 360's 1.88 is a great upgrade to 273 and 318 heads if you need new valves. Yes the seat will need a new cut and that is a good thing anyway. That is the biggest valve you can put in a 273 without notching the cylinder. I have a set of ported closed chamber 273 heads with 1.88/1.60 on my LRT 360. Not the best flowing heads but snappy.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: oem 1.88 valve question [Re: Dave_J] #2770596
05/02/20 10:58 PM
05/02/20 10:58 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Try a backcut if you use the Mopar OEM type valves, That picked up flow a bit on my 273 heads I was messing with a couple of years ago. We got it flowing about 180 cfm @ .420" lift without messing the bowl cuts. I ran out of money on that project before we tried any valve job angles, etc. Not bad for a stock head with 1.78" intake valves.
Floyd Lippencott IV
