Okay lets see some 360 build-ups (400 to 500 horse)
#276974
04/04/09 06:32 PM
04/04/09 06:32 PM
Hey guys lets see some 400 to 500 horse 360 small block build-ups. I would love to drop one in my 69 Dart next winter . Street and strip combo's.
Re: Okay lets see some 360 build-ups (400 to 500 horse)
#276975
04/04/09 06:53 PM
04/04/09 06:53 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
The current engine in my demon is a 71 360, .040 over, internally balenced, eagle rods, KB pistons 9.5 to 1 comp, ported "J" 2.02 heads, crane gold rollers, Comp hydro roller cam, studded top and bottom, Torker intake, and a quickfuel 750. Should be an easy 400hp.
#276978
04/04/09 08:24 PM
04/04/09 08:24 PM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
1991 5.9 block and heads, 9.5 to 1 compression, 2.02/1.60 valves, ported intake and exhausts, 1 3/4" headers, M1 intake, Edelbrock carb, .485" Comp Cam hydraulic roller... etc.. Runs awesome, lots of power, drives smooth as silk on the highway. Great package for what it is IMO...
CrAzYMoPaRGuY
#276979
04/04/09 08:57 PM
04/04/09 08:57 PM
Nice keep them coming , Thats in a motorhome wow!
[Re: Moparnut426]
#276982
04/04/09 09:32 PM
04/04/09 09:32 PM
Posts: 1,527 Michigan
GoDartGo
stock everything, well almost stock. speed-pro pistons w/ summit cam and ported magnum heads over a 4" bore. should be good for 399.9999 hp.
[Re: GoDartGo]
#276983
04/04/09 10:17 PM
04/04/09 10:17 PM
cool sounds like 400 is easy what about people closer to 500 horse ? I got a friend with a 500 horse conv. 09 mustang 6 speed who thinks he is really fast lol. we will see he already beat my other friends Subaru WRX STI.
#276984
04/04/09 10:31 PM
04/04/09 10:31 PM
Moparnut426
Huh even in Alaska every mustang is 500 HP. Every stang here in Nebraska is 500 HP also, just ask the owners. They all have ported 3/4 full race cams too..lol
I have spent ALOT of cash on my stroker, and Im barely gonna hit 495ish, so When its done Im hopefully gonna put the demon on a chassis dyno to find out just whats being put to the ground.
Kasey
[Re: Moparnut426]
#276985
04/04/09 10:48 PM
04/04/09 10:48 PM
Yea I know ! He also spent 65,000 for it too. lol
#276986
04/05/09 01:24 AM
04/05/09 01:24 AM
Posts: 214 Colo Springs, CO
DconD100
Colo Springs, CO
Just dynoed my new 408 for my truck today. It's got Edelbrock heads, KB forged flat tops, and a solid flat tappet cam. I run E85, and it went 578 horsepower, and the torque was 542. That's up about 60 horse over the previous lower compression, hydraulic cam version. I drove it everyday this winter to work, and I plan on driving it all year long!
Pump Gas Small Blocks Rock!
11.53 @ 116mph E85 408 at 8500 ft da,
3605 pound truck, 3.91s, street driven
[Re: Quicktree]
#276987
04/05/09 02:29 AM
04/05/09 02:29 AM
Posts: 2,637 Western Michigan
68Fastback
Western Michigan
heres my little 400HP 360. stock stroke, stock cast crank, eagle rods, probe flat top pistons, baby street roller. ported indy 360-1 heads.
Umm looks impressive Quick but do you have a big enough carb.
[Re: 68Fastback]
#276988
04/05/09 02:44 AM
04/05/09 02:44 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
+.030 360 stock crank, rods, speed pro flat tops zero deck. home ported j's, milled to 11.25cr 520/540 lift, 244/252 comp solid, torker II, 750 dp, 3400 lbs demon, 3.91 gear, 727, only time at track 1.66 60', 12.22 109.50mph
[Re: 68Fastback]
#276990
04/05/09 03:59 AM
04/05/09 03:59 AM
Quicktree
I was actually thing about putting 2 of them on there. why you think it's to big for my little 400hp motor?
[Re: Quicktree]
#276991
04/05/09 04:09 AM
04/05/09 04:09 AM
Posts: 60 iowa usa
daves72dart
iowa usa
1972 340 block Work done: O-ringed, tubed for roller cam, oil gallies enlarged, bored to 4.07(.030 over) and honed with deck plates by Herb McCandless.
340 steel crank Prepared by Lunati, stroked .110 to 3.42 stroke and balanced.
340 steel rods Prepped by Lunati. Hand picked set. All are within .001 of each other in length. Bronze bushed, balanced and lightened.
Heads 340 X heads with 2.08 intake valves and 1.60 exhausts. Double springs for .700 lift cam, Maximum porting on intake and exhaust ports.Ports are 63cc combustion chambers.
Pistons Venolia lightweight forged pistons. Uses dykes top ring, 1/16 2nd ring and standard tension oil rings. Weight is 510 grams.
Intake Holley Strip Dominator ported to match heads
Camshaft Cam Motion roller 269 275 @ .050 and .631 lift with 1.5 rocker Valves set on .024 .028 RPM range 4500-7500. Cam is degreed in at 104 deg centerline.
Other Parts High volume Melling oil pump, Comp Cams roller lifters, Crane 1.5 roller rockers(gold), Fluid Balancer, windage tray, Cloyes double roller timing set. SCE copper head gaskets(.060). Tall valve covers for use with roller rockers. Moroso 8 qt deep sump oil pan. Bronze cam gear for use with roller cams.i think it will make 525 to 550 hp and run some low 11s to high 10s.
[Re: DconD100]
#276992
04/05/09 04:46 AM
04/05/09 04:46 AM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
Interesting moder ....
what kind of compression ? .... intake and Carb ? ... how is the MPG ?
I would LOVE to put together a motor like this for my Fifth Ave sleeper.
[Re: dOrk !]
#276993
04/05/09 09:44 AM
04/05/09 09:44 AM
Yes lets see some more specs on that 408 truck motor........
