Ignition Wires #2769488
04/29/20 01:50 PM
04/29/20 01:50 PM
Thomaston, CT
Frankie P Offline OP
Thomaston, CT
Can someone tell me why the Year One date coded ignition wires cannot be used with electronic ignition?
Frank
70 Charger R/T 440 4spd Dana
Re: Ignition Wires [Re: Frankie P] #2769542
04/29/20 03:57 PM
04/29/20 03:57 PM
I think Pertronix wants no solid core wires. that's about all I can add
Re: Ignition Wires [Re: Frankie P] #2769612
04/29/20 07:05 PM
04/29/20 07:05 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Frank
These ?
https://www.lectriclimited.com/spark-plug-wire-set-215377
If so , what I can tell you is that they are CARBON CORE wires - Not that there is anything wrong with that , however I can state for a fact they are very very high ohm resistance
I had been running a set on my 383/432 Stroker for a few years now - They look great and even fit better then expected , but when it came to inconsistent RPM’s , especially higher , I was chasing my ass between ignition coils and ECU s , even fuel pressure , just couldn’t put my finger on it because it was so inconsistent
So this past month after getting my car out of storage , the first few drives on the street I just wasn’t happy
Pulled the plugs , wires , and compression test AGAIN , just looking everything over while I had time on my side
I couldn’t believe the ohm resistance on these wires when I tested them used , and even against another new set that I have here in the bag
The longest wire #7 was in excess of 20,000 Ohms brand new
OK
So last month I put on a new set of Pertronix 7mm SPIRAL CORE wires set up for a big block
I wanted to use the factory spark plug wire holders
The longest wire #7 had less then 2,000 Ohms
Beyond happy with the fit (A little long on some) , looks and PERFORMANCE difference - Night and day honestly
Picture is my old set up last year with those date coded wires
Now running a Pertronix coil that I installed last year chasing my ass , ballast resistor is bypassed on the back side - Pertronix 7mm Spark Plug wires - Same distributor - Same Mopar Chrome ECU that I have had like forever
Only thing that I changed this spring was those plug wires - Difference maker
383/432 Stroker - 75cc E Street Heads - XE275HL - Chrysler / Pertronix Ignition - 800 AVS 2
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Ignition Wires [Re: bee1971] #2769620
04/29/20 07:22 PM
04/29/20 07:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
the factory used carbon core wires with electronic ignition.
So who knows what Year One is thinking.
Re: Ignition Wires [Re: Sniper] #2769644
04/29/20 08:42 PM
04/29/20 08:42 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Electronic Ignition wires where Orange correct ?
Not that it matters
However was 1972-1974 Factory Electronic Ignition Wires 7mm or 8mm ?
Thanx
Siberian Huskies
Re: Ignition Wires [Re: bee1971] #2769651
04/29/20 08:54 PM
04/29/20 08:54 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You are asking the wrong guy here, I don't do resto stuff so I don't know the answers you need.
I do know the factory used carbon core wires on electronic ignitions though, because I replaced many of them over the years. Cheap radio interference suppression that still carried enough energy to fire the plug was all they cared about.
I suspect the person having the issue with the repro ones was due to poorly made wires and not that they were carbon cored.
Re: Ignition Wires [Re: Sniper] #2769652
04/29/20 08:58 PM
04/29/20 08:58 PM
Long Island, New York
57Fury440 Offline
57Fury440  Offline
I have my original wires from my 72 barracuda and they are 7mm.
Re: Ignition Wires [Re: bee1971] #2769687
04/29/20 10:54 PM
04/29/20 10:54 PM
Not that it matters
Thanx
I think the factories, all American car makers, started using resistor carbon core 7 MM spark plug wires in the mid 1960s under Federal mandate I believe . shruggy
The good Packard 440 spark plug wires where either copper core or tin plated copper wires before that scope
I'm sure none of the American car makers used 8MM spark plug wires on production cars.
Re: Ignition Wires [Re: Cab_Burge] #2769716
04/30/20 07:36 AM
04/30/20 07:36 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Thanx
Good to know info
Siberian Huskies
Re: Ignition Wires [Re: Frankie P] #2769745
04/30/20 09:42 AM
04/30/20 09:42 AM
Thomaston, CT
Thomaston, CT
I ask this question because I'm planning on using Mopars electronic ignition kit in place of a points distributor. On Year Ones website when you look for date coded ignition wires at the end of the product description it states "not for use with electronic ignition".
Re: Ignition Wires [Re: Frankie P] #2769768
04/30/20 10:29 AM
04/30/20 10:29 AM
57Fury440 Offline
57Fury440  Offline
Electronic ignition was an option on the barracuda in 1972. I ordered mine with it and it came with the orange wires. I think the black wires are correct only on the points ignitions.
