aeromotive 340LPH electric pump ? #2767818
04/24/20 12:17 PM
04/24/20 12:17 PM
moparx Offline OP
moparx  Offline OP
anyone ever run an in tank aeromotive 340LPH fuel pump in the tank on a carbed setup ?
if so, how did it work ?
was it able to be regulated down to 5-6psi ?
as always, TIA ! bow
Re: aeromotive 340LPH electric pump ? [Re: moparx] #2767841
04/24/20 01:11 PM
04/24/20 01:11 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I had the 255lph & it was no problem, 3/8 supply,3/8 return,, as long as the return is large enough it would work, it might need a 1/2in return
My 450lph will not go that low with the 3/8 return
Re: aeromotive 340LPH electric pump ? [Re: moparx] #2768033
04/25/20 09:58 AM
04/25/20 09:58 AM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Not a carbed setup, but I run one in my 2000 BMW M5. Works great. It has a good reputation for performance and reliability and I wouldn't hesitate to put one in a carburated setup with a good regulator and return. I think there are PWM controllers that can vary the voltage to the pump depending on the engine demand.
Re: aeromotive 340LPH electric pump ? [Re: gzig5] #2768401
04/26/20 12:21 PM
04/26/20 12:21 PM
moparx Offline OP
moparx  Offline OP
thanks guys ! up i was planning on a 1/2" return, as i have a 3/8" feed now. i have a holley "blue" regulator [actually, two of them on the shelf, one being new] i was planning to use, after i obtain a rebuild kit. would that regulator work ?
in the future, i may convert to fuel injection. would this setup work reasonably well if i used it on the FI ?
beer
Re: aeromotive 340LPH electric pump ? [Re: moparx] #2768404
04/26/20 12:28 PM
04/26/20 12:28 PM
Pattison Texas
Pattison Texas
beer
is it a return type regulator ? if yes, there is a spring for low & one for high pressure.
Re: aeromotive 340LPH electric pump ? [Re: CSK] #2768407
04/26/20 12:39 PM
04/26/20 12:39 PM
moparx Offline OP
moparx  Offline OP
i'm not sure. the new one has three ports, all 1/4"NPT.
beer
Re: aeromotive 340LPH electric pump ? [Re: moparx] #2768413
04/26/20 12:59 PM
04/26/20 12:59 PM
Pattison Texas
Pattison Texas
beer
Check the part #, a pressure regulator will not work as a return regulator.
Re: aeromotive 340LPH electric pump ? [Re: CSK] #2768690
04/27/20 10:39 AM
04/27/20 10:39 AM
Maryland
mrob Offline
mrob  Offline
Maryland
I have a Holley Sniper EFI tank with internal 255lph pump and used an Aeromotive 2 stage pressure regulator (P/N 13220) with a carburetor. That regulator is specifically designed to regulate an EFI pump for a carbureted engine. I set my fuel pressure at 6 psi and it holds rock solid.
Here's a link to the regulator: https://aeromotiveinc.com/product/efi-2-carb-dual-fuel-pressure-regulator/
Hope this helps
Re: aeromotive 340LPH electric pump ? [Re: mrob] #2769001
04/28/20 09:05 AM
04/28/20 09:05 AM
Deep DEEP SOUTH
LAD 524 Online content
LAD 524  Online Content
Deep DEEP SOUTH
Got a 340 lph Aermotive in my tank, 1/2" feed and return, Aermotive return reg, has been flawless feeding a 572" NA Hemi. wink
Re: aeromotive 340LPH electric pump ? [Re: LAD 524] #2769063
04/28/20 11:56 AM
04/28/20 11:56 AM
moparx Offline OP
moparx  Offline OP
well, it sure is "enlightening" if one takes the item out of the box and reads the instruction sheet ! laugh2
first of all, the port size is 3/8"NPT, and the regulator is one "in" port and two "out" ports.
secondly, the part number is 12-803. according to the instructions, if this was a return regulator, the part number would be 12-803BP [bi-pass].
so i need to go regulator shopping.
it looks like the aeromotive pump will do what i want it to, thanks to those that have responded with their personal experiences. up
i now have a 3/8" feed line, but i think i will remove that and go to 1/2", since i have to fab a return anyway.
i was thinking of plumbing the return into the filler neck just before it goes into the tank. is that an ok choice ?
beer
Re: aeromotive 340LPH electric pump ? [Re: moparx] #2769072
04/28/20 12:12 PM
04/28/20 12:12 PM
Pattison Texas
Pattison Texas
beer
I would not put it in the filler tube, fuel will be going all over the place inside the tube, & if you ever opened the fuel cap with the pump on I bet fuel would blow out all over you & the car. the vent at the top of the neck would also be compromised & leak out raw fuel. just my two cents
Re: aeromotive 340LPH electric pump ? [Re: CSK] #2769081
04/28/20 12:31 PM
04/28/20 12:31 PM
moparx Offline OP
moparx  Offline OP
good points ! i just didn't want to weld on my new stainless tank.
there is no room [at least i don't think there is] to weld in a 1/2" return on the sending unit, so i'll be thinking on another location.
this is down the road a piece. i have the forward radiator/ac condenser mount finalized and done, so the next item on the list is frame connectors.
then motor/transmission removal, underhood restoration, new engine/transmission combo, fuel system, exhaust, etc.
man, i hope i can get this done THIS year !
it's been TOO long since i've had a toy to play with. always fixing other's stuff. [now working on a very good friend's wiring issues on his tractor]
also, [decorative] garden work for my lovely bride. [hard to believe it's been 41yrs we have been together !]
beer
Re: aeromotive 340LPH electric pump ? [Re: moparx] #2769094
04/28/20 01:08 PM
04/28/20 01:08 PM
Pattison Texas
Pattison Texas
beer
The sending unit can be modified with a 1/2 return, the 3/8 supply will work just fine, also HAPPY Anniversary to Y'all from Katy Texas smile
Re: aeromotive 340LPH electric pump ? [Re: CSK] #2769415
04/29/20 11:04 AM
04/29/20 11:04 AM
moparx Offline OP
moparx  Offline OP
thanks charlie ! july 20 is the date. boogie
beer
