Re: White smoke drivers side?
[Re: moparvinson]
#2768753
04/27/20 03:16 PM
04/27/20 03:16 PM
RapidRobert
You might pressurize the coolant system. you can get a "tank valve" from O'reillys for less than $3 & it has an 1/8NPT male end & screw it into the coolant sensor port & use your air hose on the schrader valve & go to maybe 15 psi. be carefull & add air in short blips then use your tire psi gauge so you dont blow out the system. Sure sounds like a coolant leak on the driver side. Holler how it goes.
[Re: moparvinson]
#2769053
04/28/20 11:18 AM
04/28/20 11:18 AM
Posts: 10,713 North Dakota
6PakBee
North Dakota
If it's blowing white smoke at idle, stick your face in the exhaust and see if it tastes sweet. If it does, you have a coolant leak.
[Re: stumpy]
#2770407
05/02/20 11:41 AM
05/02/20 11:41 AM
Posts: 261 Albuquerque, new mexico
moparvinson
Haven't had time for pressure test yet but my son pulled spark plugs, they all look the same? He also bought one of those test kits to check water for exhaust and it tested good? Water is still clean and he hasn't had to add any yet and oil is still clean? He has been driving it a bit to test it and car is still running good and temp gauge is only getting to about 1/4
