Pool filter media question
#2767309
04/23/20 05:42 AM
04/23/20 05:42 AM
Posts: 5,651 Port Huron, Michigan
MI_Custumz
I currently use a Hayward sand filter and it requires 150 lbs of sand. A co-worker said there is a new product out and it weighs next to nothing. I looked it up and found it, but not sure how well it works and which exact product to get. I need to change my sand next year or the year after, I would have to look. 150 lbs of sand is hard to get rid of since I really have no place to dump it. These new things can get tossed in a garbage bag since they are so light. If it filters better and is less dense as advertised, I would imagine it would be less strain on the pump itself as well. Has anyone used these and if so, are they better than sand? http://www.filterballs.com/
Re: Pool filter media question
[Re: MI_Custumz]
#2767338
04/23/20 09:40 AM
04/23/20 09:40 AM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
I haven't seen that media before. I like the idea that it is back washable Vs the cartridge filters I am currently using.
The cartridge filtration I am using is cleanable but that involves removing the cartridge and rinsing the debris off of it. In the event of an algae bloom I find I can kill the algae in the pool but the algae trapped in the pleats still is green and is alive despite being deprived of light. I do use a bucket with a chlorine and water mixture to kill it but the higher levels of chlorine required attacks the end caps.
If I wait till the cottonwoods bloom before I open the pool I have a much better but shorter season.
I look forward to other responses as I am thinking about switching to sand.
TY K
[Re: MI_Custumz]
#2768297
04/25/20 11:12 PM
04/25/20 11:12 PM
Posts: 1,411 Tallmadge, Ohio
Paul_B
Tallmadge, Ohio
When I had a sand filter and needed to change out the sand, I switched from sand to a product called Zeosand Zeosand as recommended by the local pool store. With this Zeosand, you use half the weight (100 pound of sand would require 50 pounds of Zeosand) as you would with sand. Worked maybe a bit better than regular sand. I switched over to a DE type filter when my sand filter failed. This filter gives me better water clarity and I go much longer between backflushing than when I had a sand filter.
[Re: MI_Custumz]
#2769035
04/28/20 10:45 AM
04/28/20 10:45 AM
Posts: 1,637 Florida
GMP440
I would just take that sand and spread it all over the yard. If you have depressions or holes in you yard you can fill it with the sand. As someone stated already about a cartridge filter. I would get rid of the sand filter and put in a cartridge filter . So much easier to maintain. Sand is old technology. Time to update. Had the cartridge filter setup for my swimming pool at my old house. It was easy to clean , loved it.
[Re: MI_Custumz]
#2769082
04/28/20 12:32 PM
04/28/20 12:32 PM
Posts: 2,113 Byron, NY
W.I.N. Racing
Byron, NY
I too had a Cartridge filter when I first bought my pool and could seldom get the water stable, Once I switched to sand it became much easier to keep things stable.I don't know under what type an environment (maybe indoors) a cartridge filter system would work well...just spread the sand around the yard is my vote as well.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2769110
04/28/20 01:38 PM
04/28/20 01:38 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
We had a cartridge on ours when we moved here.Finally got a sand filter.The cartridge according to the pool people we use is for pretty much hot tubs and spas not pols.they ysed to use them pretty much because they were easy to get.Our hayward sand has been omn at least 6 or 7 years and all we did was add some sand./Just use the pool sand and not play sand.The cartridge we had were pricey Buy maybe one or two and you have a sand filter.yeah we washed them but they never filtered as good as sand.Rocky
Chrysler Firepower
[Re: therocks]
#2769294
04/28/20 10:06 PM
04/28/20 10:06 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
I've never heard of the filter balls before. We use a DE filter and when we back flush it, the de goes away with the wastewater. Then we just add more de.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
