Let's see your electric fan solutions #2767195
04/22/20 07:03 PM
04/22/20 07:03 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
Are there any high flow electric fans out there that do not require electronics to run. Not interested in the Mercedes fan for this reason. Suitable fans should be able to be modified to fit typical oem brass or aftermarket aluminum radiators in our Mopars and clear typical water pumps. No pusher fans. No PWM boxes unless they are readily available anywhere. I've seen the HHR and Ford fans. Do they flow enough for street duty or are they best used by race cars? Anything else out there?
Re: Let's see your electric fan solutions [Re: GomangoCuda] #2767200
04/22/20 07:34 PM
04/22/20 07:34 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
ANY fan will work. For compactness the Dodge Neon fans can't be beat and you can get them at Pick and Pull for next to nothing.
I'm running a wimpy fan of unknown origin (rumor it came out of a Dodge Omni), direct wired to a 10 amp toggle switch and it cools my 5600 pound 4x4 360 no problem.It turns slow because of the switch but it's not an issue. I've even pulled a trailer with it and still never had a problem.
Mo' Farts
Moderated by "tbagger".
Re: Let's see your electric fan solutions [Re: Grizzly] #2767204
04/22/20 07:44 PM
04/22/20 07:44 PM
Guitar Jones Offline
Could be where you live too. 120 in the dessert is a tad different than Fargo ND.
Re: Let's see your electric fan solutions [Re: GomangoCuda] #2767208
04/22/20 07:58 PM
04/22/20 07:58 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Ford Contour fans are keeping my Dart's big-cam 451 cool at least in 86F temps. They cycle on and off about every 30 secs while idling at a standstill for prolonged periods.
I'm using a swapmeet copper-brass radiator, not sure what it came out of, just narrow enough to fit in there.
(If it's much hotter than that I won't be driving the Dart anyway, with no a/c!)
Re: Let's see your electric fan solutions [Re: DrCharles] #2767216
04/22/20 08:23 PM
04/22/20 08:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've used SPAL fans on a few custom deals. Nice, quality. And to my knowledge still made in Italy. Not China junk.
Re: Let's see your electric fan solutions [Re: CMcAllister] #2767218
04/22/20 08:38 PM
04/22/20 08:38 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
My brother has a twin fan unit out of a supercharged Pontiac Bonneville and it moves a lot of air. It's in a GM car with a crossflow radiator so it may be the wrong shape to fit a Mopar radiator.
Get the biggest one that covers as much of the radiator as you can..
Re: Let's see your electric fan solutions [Re: CMcAllister] #2767219
04/22/20 08:39 PM
04/22/20 08:39 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
I have the Derale dual fans & their PWM, works great, 512ci,Cold A/C, southeast Texas heat, 180ish all day long, had to grind a spot on each outer fan plastic holder to clear the water pump pulley
92643008_2935127073212649_8903986010887553024_n.jpg91964999_2935826903142666_8178780628339130368_n.jpg
Re: Let's see your electric fan solutions [Re: GomangoCuda] #2767220
04/22/20 08:48 PM
04/22/20 08:48 PM
Andrewh Offline
Andrewh  Offline
the Mercedes fan has a few different versions.
the factory versions have one that do not require any extra electronics, but it is then only an on and off, vs a ramp up based on temp.
the thread shows pics or a description of the different ones out there.
Re: Let's see your electric fan solutions [Re: GomangoCuda] #2767241
04/22/20 09:32 PM
04/22/20 09:32 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Chevy HHR fan. I have used them on several builds with no problems. They move lots of air and you can find new ones on EBay for around sixty bucks.
Re: Let's see your electric fan solutions [Re: Dabee] #2767247
04/22/20 09:51 PM
04/22/20 09:51 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I have Ford Contour fans on the 5.7L Hemi and they will cool the car in Texas Summers on low speed.
I run the fans on high speed when the a/c is on and they move a TON of air. Ensure your charging system is up to par with any of the solutions out there. I'd really consider using a PWM fan controller, if I were you. Yes, those are "electronics", but they are very effective for managing electrical loads.
I had a HHR fan with the 318, which also worked pretty well.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Let's see your electric fan solutions [Re: GoodysGotaCuda] #2767273
04/22/20 11:29 PM
04/22/20 11:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run the dual fans out of a late model Challenger/Charger/300. Easy to adapt.
Doug
Re: Let's see your electric fan solutions [Re: GoodysGotaCuda] #2767278
04/23/20 12:04 AM
04/23/20 12:04 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Good to know. So it probably will work for a bigger engine in the heat, on high speed.
Quote
iagree I am about to do just that... I did a simple installation with both fans wired in parallel for full voltage only, and a hefty 80 amp relay to turn them on and off. Does a great job keeping the 451 cool, but with my huge (for the street) cam, when the electrical load suddenly comes on, it can really pull the RPM too far down (especially if coming to a stop at the same moment).
Quote
I tried that first, but the HHR would not fit between the water pump nose and the radiator in my A-body. And it can't be run as a pusher by reversing the motor, because the blades are scooped the wrong way. Other than the enormous Mercedes fan, the Contour pair seems to be a good solution all around. twocents
Re: Let's see your electric fan solutions [Re: DrCharles] #2767399
04/23/20 12:18 PM
04/23/20 12:18 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
This is where I would take advantage of a PWM fan controller. Wire the PWM controller to the high speed windings on the fan and let it manage temp between 0% and 100% high speed, you won't have a problem. Ever.
2020 RAM 1500
Re: Let's see your electric fan solutions [Re: dvw] #2767404
04/23/20 12:24 PM
04/23/20 12:24 PM
moparx Offline
moparx  Offline
Doug
i'm doing the same fan setup on my charger now, although i don't have any pics. my fan is for a 2016 model year with the 6.1 [i think ? the bigger one below the hellcat version] hemi.
i am also upgrading my alternator to a 95 amp denso, and will be running my fans through a relay system at the very least, although i'm also considering a PMW controller.
beer
Re: Let's see your electric fan solutions [Re: moparx] #2767437
04/23/20 01:35 PM
04/23/20 01:35 PM
Eastern Shore of Maryland
N
nasty68 Offline
nasty68  Offline
N
I also run the ford contour fans. I use a flex-a-lite controller to run them. Soft start up and they run faster or slower depending on what the car wants.
I also have a switch hooked up that will run them on high if i need to.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: Let's see your electric fan solutions [Re: CMcAllister] #2767825
04/24/20 12:33 PM
04/24/20 12:33 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
That's the answer! After my junkyard fans centrifically exploded after a 145 MPH pass I bought a 16 inch spal pusher fan that cools my 545 inch blown hemi. 185* when it's over 90*.Back at the starting line it's down to 160*.
The spal fan was $135 and their mounting system is easy peasy. up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Let's see your electric fan solutions [Re: hemi-itis] #2768379
04/26/20 11:14 AM
04/26/20 11:14 AM
moparx Offline
moparx  Offline
-itus, did you add the lightning holes ?
beer
