Comp Cam ID again #2763138
04/12/20 05:44 PM
04/12/20 05:44 PM
birdtracker Online boogie OP
birdtracker  Online Boogie OP
looking for some info or cam card for this Comp Cam. Especially hot or cold lash. Thanks Birdtracker
Re: Comp Cam ID again [Re: birdtracker] #2763171
04/12/20 07:35 PM
04/12/20 07:35 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I found this shortly after my post:
https://www.compcams.com/lobe-catalog
Re: Comp Cam ID again [Re: mgoblue9798] #2763516
04/13/20 04:15 PM
04/13/20 04:15 PM
thanks for the link, I will try and figure out where this one is. Birdtracker
Re: Comp Cam ID again [Re: birdtracker] #2764640
04/16/20 02:27 PM
04/16/20 02:27 PM
Any idea of what section or the grind number. Birdtracker
Re: Comp Cam ID again [Re: birdtracker] #2764666
04/16/20 03:42 PM
04/16/20 03:42 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Comp Cam ID again [Re: ZIPPY] #2764775
04/16/20 07:52 PM
04/16/20 07:52 PM
so after looking thru some of it, I found one on page 81. It says .645 lift. It was my understanding this cam was .665 on the intake and .645 on the exhaust. Also once you find the cam can you find a cam card with valve lash specs or is this somewhere else. Birdtracker
Re: Comp Cam ID again [Re: birdtracker] #2764952
04/17/20 10:12 AM
04/17/20 10:12 AM
NC
440Jim Offline
440Jim  Offline
NC
I would call Comp tech assistance and give them the serial number and lobe numbers on your cam. They should be able to provide lash (which depends on the rocker ratio you use).
I find it easiest to download the Comp Catalog, open it with Adobe (PDF) and use the search (magnifying glass icon) to find the lobe number.
That intake lobe lift shows 0.442" so using 1.5 rockers it calculates to 0.663" lift.
Re: Comp Cam ID again [Re: 440Jim] #2765270
04/17/20 09:43 PM
04/17/20 09:43 PM
Jim: thanks for the info. I tryed email once with Comp but did not get a reply. I wonder if they are open. Birdtracker
Re: Comp Cam ID again [Re: birdtracker] #2766903
04/21/20 08:48 PM
04/21/20 08:48 PM
Just for everyones info Comp Cams tech line is up and running. Got ahold of them after like 5 minutes on hold. Got all the info and lash specs. Birdtracker
Re: Comp Cam ID again [Re: birdtracker] #2766997
04/22/20 06:07 AM
04/22/20 06:07 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Well spill it.
Re: Comp Cam ID again [Re: 572B1] #2767009
04/22/20 08:38 AM
04/22/20 08:38 AM
It’s split both duration and lift on intake and exhaust. .663 lift on intakes with 266 duration. 645 on exhaust with .260 duration. I had this motor running very little with this cam. It was very responsive but I have not had it on a dyno or made any passes. Birdtracker
Re: Comp Cam ID again [Re: birdtracker] #2767111
04/22/20 02:06 PM
04/22/20 02:06 PM
NC
440Jim Offline
440Jim  Offline
NC
I think you typed that backwards. Isn't it
260 deg 0.663" lift Intake
266 deg 0.645" lift exhaust
What was the lash they recommended?
Re: Comp Cam ID again [Re: 440Jim] #2767135
04/22/20 02:56 PM
04/22/20 02:56 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Lash can be fine tuned to the combo, so any recommended lash on the cam card is really just a suggested starting point imo.
For that cam, I’d start at .020/.022 hot.
Re: Comp Cam ID again [Re: fast68plymouth] #2767170
04/22/20 05:30 PM
04/22/20 05:30 PM
Recommended was .016 intake and .018 exhaust. I do plan on opening it up as cold the intake lash would be close to zero. I check it when I ran it a few times and with the aluminum block and heads , lash grew .016. I set them at .010 cold for the initial fire up. Think I am going to do .005 this time. Birdtracker
